Old 08-23-2005   #1
wikdzr1
Default Chain Rattle at start up
I have a 92 ZR1 with 60k miles, only during start up the chains rattle for a quick second I assume until presure increases. Should I worry about this, if so what should I do?
regards,
Brett
wikdzr1 is offline   Reply With Quote
Old 08-23-2005   #2
yellowz
Default rattle
brett
there has been a design change to the right hand tensioner.If you are concerned with the rattle have that changed however its an expensive part.
my 92#475 white/white had the noise and i updated to the new tensioner.
peter
yellowz is offline   Reply With Quote
Old 08-23-2005   #3
ZR1 MK
Default
Its not much of a concern, but thicker oil will help while an updated right side chain tensioner, preoil pump or accumulator will eliminate the problem.
ZR1 MK is offline   Reply With Quote
Old 08-24-2005   #4
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
Default
Originally Posted by yellowz
brett
peter
What exactly does "expensive" mean?
Jim Jones is offline   Reply With Quote
Old 08-25-2005   #5
ZR1 MK
Default
Approx $220 in parts plus labor.
Old 08-26-2005   #6
rbidwell
Default
If you decide to replace the right side chain tensioner you will need a special tool to set it after it's installed. I have one that I can send you, if you would send it back when you are done with it. ron
rbidwell is offline   Reply With Quote
Old 08-29-2005   #7
wikdzr1
Default
Thank you, how big of a job is it? Are there any pics or instructions anywhere I do have a service manual.
Regards,
Brett
Old 08-29-2005   #8
40th#381
Default
I Had Cam Chain Rattle @ start up with my 93. I started useing Mobil 1 (M1-207) oil filters and 10W-30 Mobil 1. Hasen't happened again.
Jan
40th#381 is offline   Reply With Quote
Old 08-29-2005   #9
rbidwell
Default
I don't consider myself a great mechanic and I didn't have any problems. Just follow the instructions it isn't too bad of a job. You might want to read this. http://www.corvetteforum.com/techtip...D=46&TopicID=2
Old 08-31-2005   #10
wikdzr1
Default
Thanks for the info, come to think of it I just changed my oil & filter. I will put on a Mobil one filter & let you know.
