Old 02-14-2009   #1
Bob Seliga
Bob Seliga's Avatar
Default FX3 Selective Ride Control
I just received the Fault code diagnostic grounding plugs and the manual from Gordon Killebrew yesterday. Everything checked out fine except the Ride Control System. Each and every code showed up as a fault. Is there a main controller that might cause this to happen? I can't believe that each individual part of the system went out at the same time.
Bob Seliga is offline   Reply With Quote
Old 02-14-2009   #2
Jeffvette
Default Re: FX3 Selective Ride Control
The brain is mounted in the compartment with the ABS controller.
I would clear the codes and then start the car again and go from there.
Old 02-14-2009   #3
Tyler Townsley
The most common problem is the rod in the shock that turns to adjust the ride, it starts to bind and will cause the gear that turns it to break/strip. Some have had success making a new gear out of star washers after getting the shock fixed by Bilsteen.
Tyler
Old 02-16-2009   #4
Bob Seliga
Bob Seliga's Avatar
Thanks for the help. I cleared the codes and got code 33 showing the LR out of position. Pulled the shock and the little gear on top has a broken tooth. Can this be replaced or does the shock need to go back to Bilstein?
Old 02-16-2009   #5
Tyler Townsley
I would send the shock to be redone. The gear usually breaks because the rod begins to bind up.
Tyler
Old 04-28-2009   #6
max76
Hi guys,
i'm Max from Milan, Italy...i'm new of the forum...
I have the same problem of Bob...i have done the Fx3 ALDL test and i have all the error code.
How i can delete/erase these error??
Thanks in advance
Ps: i read a lot of pages of this forum and i give you my compliments for that, it's very interesting...i learn a lot of things!!!!!
Bye
max76 is offline   Reply With Quote
Old 04-28-2009   #7
http://captainzcnc.com/index.html
Bob take a look at the link for repairs to the actuator.
Old 04-28-2009   #8
max76
Tom, thanks for the link, but i need the method to delete the memory of Fx3 Chip...
Thanks again
Max
Old 04-28-2009   #9
Max, I have a 90 and I know that there was changes made in the system in the 92(?) thru 95's. I know Jeffvette made a thread and it's here somewhere.
In a 90 to clear all the codes you will find the "C" terminal pin on the ALDL connector. Ground Pin "C" three times, each "grounding" of the pin "C" will be for a duration of two (2) seconds.
Old 04-28-2009   #10
max76
OK tom, i must put a cable to pin "C" and the "-" pole of the battery (or the body vehicle) for 3 times and evry time have 2 seconds of duration. It's right?
Thank you
Max
