I have done some searching and can not find what I am looking for or the answer is there a I missed it
![]() 1. Replace the prom. 2. Replace the key switch with a momentary contact switch? 3. Relocate the key switch to another accessible location. Any suggestions as to where? It is fairly large. Questions? 1. Replacing the prom would I still need the switch connected? This seems to be kinda of a stupid question but you never know. 2. Using a momentary switch what rating should it be? At this time I have been unable to find another radio bezel for the ZR1 which could be used to be modified. |
Just buy a stock Bezel for your car and modify it. The fits the same minus the key and module. Jeffvette did this and also added his Valentine radar detector hidden display module to the lower left of the bezel and he moved his key over to the middle right of the bezel. ask him for a picture it will give you a pretty good idea of what to do. It was a very clean install.
Thanks. I will.
#4 | |
Darryl, the 90 key cylinder is completely different from the 91+. ![]() |
Jeff,
That looks sweet ![]() |
Yes I know no module (91-95 only) but it can still be moved over I beleive.
Unless its epoxied to the new postion. I know I know
![]() But Jeffvette is right behind the stock ZR-1 91-95 bezel is indeed mounts to secure into.
#9 |
Thanks for everyone's help
