01-29-2009 | #1 |
Radiator
I received a price of $389 for a new aluminum radiator from Entropy Technology Corp. Has anyone heard of these guys. If so any comments would be appreciated.
01-29-2009 | #2 |
Re: Radiator
01-29-2009 | #3 | |
Re: Radiator
Many say Ron Davis is the best radiator, but many have gotten Dewitts as well. If you need the best cooling and have the means.... I would go with either of them. |
01-29-2009 | #4 |
Re: Radiator
The OEM radiator that is offered by thepartsladi is made by Delphi. It will fit in a ZR-1, but be aware that it is the radiator that is used in C4 Corvettes with an automatic transmission. The radiator has two fittings on the right side tank and a transmission cooler inside the right tank that are not on an original radiator for a manual transmission car.
This pic shows one of one of the extra fittings and you can see the "cooler" in the outlet pipe. The radiator will fit perfectly in a ZR-1 and the extra fittings cannot be seen when the shroud is installed. I am not familar with the radiator that you mention in the OP. The important question for any after-market radiator is the fin area thickness. both the DeWitts and the Ron Davis radiators are thicker that the stock radiator. They require either trimming the fan shrouds by cutting off 5/8 inch of material, OR installation of spacers to hold the fan shroud away from the radiator core. (Ron Davis recommends cutting, see their web site, and DeWitt sends the spacers) Here is a picture of my LT5 with the spacer in place: I hope this helps. Jim
01-29-2009 | #5 |
Re: Radiator
I went with Fluidyne
01-30-2009 | #6 | |
Re: Radiator
The main issue is after 17 years of filth, sand, grit and road grime, bent cooling fins, loose paper bags, Leaves, cigarette butts etc build up on, in, around the shroud area and the radiator itself fails. All a larger radiator does is buy you more cooling time if your stuck in heavy traffic and lesson recovery time due to the extra capacity. About the best feature of an all aluminum radiator is the lack of the plastic end caps but unless you a fulltime track racer its just not needed and I live in Arizona and can tell you a new OEM radiator that is maintained will provide ample cooling capacity for any C4 Now back to your question. I have never heard of that brand before but if I was going to go with an aftermarket alternative I would go with either the Dewitts or Fluidyne as listed by Jim and what Phil uses. I am not a fan of spacers or cutting the shroud but hey thats me.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-30-2009 at 11:44 AM. |
01-30-2009 | #7 |
Re: Radiator
Thanks Guys,
It looks to me like Dewitts is the best deal. I'll be ordering within the next couple of weeks - got other projects underway right now. You guys should think about comming to Spring Mountain in March for the Corvette Track Days. I need some help whipping up on the newer cars. |
02-01-2009 | #8 | |
Re: Radiator
Think A Dewitt's will be in mine soon from all the info posted and I'd rather do spacer's than cut. Let me know if the Dewitt's help's on the track. Above 80 deg. had to back off for cool down on mine, but it would cool down fast when backed down.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
