![]() Join Date: Aug 2006
Hi, all ZR1ers,
After cold start in the morning (I have a 94 #256 which I drive daily with 105,000 miles) 1-2 minutes after the start I started to hear a sort of groaning/gritty noise. At first I thought it was coming from the motor or one of accessory drive/pully but could not identify the source. Another 2-3 minutes and then the noise goes away. Then I noticed even at warm start (15 minutes or so after shut down) I get the same type of noise. I am beginning to suspect anti-lock system trying to go through self check sequence. Could someone tell me what generates 30 second or so of squealing type of noise following the start? |
Well there are normal noises I hear on my daily driver before and after starting it up are:
1. The Fuel Pumps will whurr when turing the key before starting the car 2. Chain tensoner rattle for about 3 secs until the oil is pushed up from the pan 3. The Air Pump runs as long as a minute, Depends how cold it is outside 4. The ABS self check sequence after backing and then proceeding forward a few feet, The ABS light will also flicker So if these are not the noises you expect maybe a alternator bearing or ?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-29-2009 at 01:17 PM. |
There is a sequence of noises as described by our Cycloptic friend.
1. Key on, fuel pumps pressurize the fuel system 2. Once engine starts, the secondaries vacuum pump fires up for about 30-50 seconds 3. The SMOG air pump fires up and runs for 2 or 3 minutes 4. The ZF6 makes it's signature noise until the clutch is depressed. Try depressing the clutch and see if the noise abates. Worn pilot bearings and throwout bearings can and do makes weird noises. If it's coming from under the hood, items 2 & 3 might be worth looking into. Where are you located? I'm sure one of the boys wouldn't mind coming by to take a listen and help you with the diagnosis. TomC "Crabs" |
I'm over in Fairfax, VA and would be glad to have a look at it.
Sometimes on the GM mag clutch for the AC compressor will make funky noises when AC is off (thus clutch not engaged)... try turning on the AC and see is noise ceases... just one option of many already posted
Does the noise you hear occur with the car sitting still or as you start to drive?
I am sure that Phil (Jagdpanzer) and Michael (ZR1Vette) will give you some expert advice. If you need any other help, post again or PM me. There are a lot of knowledgable ZR-1 owners nearby to you. Also, if you want to be informed about the activities of the ZR-1 owners and get togethers in the Maryland and northern VA area, PM me and I will add you to our list. Jim |
Wow!
I know ZR1 guys are tight-knit bunch but what a response! Now that you guys have pointed out, most likely in sequence; 1. Throwout bearins. 2. Possible air pump. 3. AC clutch. 4. Possible air pump. She has been idling a little high, so during the weekend I will spend sometime and dismantle idle solenoid and clean it out. I will try to locate the noise at the same time. Noise ocuurs with engine running whether stationary or while moving. Thanks guys. |
#8 | |
1. Throwout bearing: the noise will only occur when the clutch pedal is pushed in. 2. Air Pump: Raise the hood. The air pump is in the well in front of the left front tire. Put your hand on it and see if it is vibrating when you hear the noise. 3. AC Clutch: When you have the noise, turn off the AC system (OFF button on the dash). Another posibility is the AC blower fan. Turning the AC on and off and/or changing the fan speed should affect the noise if that is it. A high idle may also be caused by a vacuum leak. Good luck. Let us know if we can help. Jim |
#9 |
I have had my serpentine belt stretch out so far it 's backside was slapping itself. Of course the A/C exaggerated it and the tell tale signs was a lot of pulverized rubber particles under the air horn area. I am actually using one size smaller belt than OEM now.
#10 |
Thanks. for all your input.
If and when I find what the culprit was I will repost for record sake. Thanks. |
