Old 01-27-2009   #1
Bob Seliga
Bob Seliga's Avatar
Default Passenger side O2 sensor
Got a code suggesting a problem with the O2 sensor. The drivers side was easy. Passenger side not so much. I got the old one off but my hands donfit between the block and the motor mount. Can it be reached pull the fender well apart?
Bob Seliga is offline   Reply With Quote
Old 01-27-2009   #2
Jeffvette
Default Re: Passenger side O2 sensor
Bob, drop the passenger side K-rail, and then the shielding that holds the sensor harness in place will come down. It's a tight fit and it seems like every car is different. But that should help. It has two 15mm bolts and two 13mm bolts holding the k-rail in place, plus the 19mm motor mount bolt.
Old 01-27-2009   #3
Bob Seliga
Bob Seliga's Avatar
Thanks for the information Jeff. I'll give it a try this weekend.
Old 01-30-2009   #4
rogerzr1
rogerzr1's Avatar
It is a pain in the azz!!! I ended up getting a O2 wrench that hinges. Jeff is the one that put me on to it. I don't think I could have done the job without it!! Then I had problems with the wire harness being too short -----hope you don't have that issue. Good luck.
rogerzr1 is offline   Reply With Quote
Old 01-31-2009   #5
rhipsher
rhipsher's Avatar
Extended angle needle nose pliers and a long flat head screw driver will reach. But you still have to do what jeff said to make room.
Old 02-01-2009   #6
Bob Seliga
Bob Seliga's Avatar
Thanks for all the advice. It wasn't as bad as I thought it might be. A few more things on the list and I'll be back on the road.
