Old 08-18-2005   #1
Nick
Default LT5 Spark Plugs
What spark plugs are you guys running? My lightly modified LT5 runs very well on the GM specified AC Delco 41-913's. I recently tried a set of Rapidfire #5's and I'm having some problems with detonation. I think the plug's heat range is too hot, so I'm going to try a set of Autolite double platinums, for no other reason than availability and price ($4 apiece versus $10 apiece for the AC Delco 41-913's).
My research indicates that the Rapidfire #5 will work, if you start the engine and don't warm it up before driving, and if you do not drive it aggressively. Anybody here fit that criteria?
I also understand that the Rapidfire #9's might work better. Comments?
Old 08-18-2005   #2
1990 quasar blue
Default
Nick, I'm currently running the colder of the rapid fire plugs. I get some hesitation, especially when the car isn't completely warmed up. Mark Haibeck said that the rapid fires are known to cause that problem and recommended the NGK TR7IX Iridium. I ordered a set and then realized that they are a tapered seat, and having a 1990, I would have to do the over torque thing. I'm still on the fence about whether or not to do it so I can't tell you if they made an improvement.
Old 08-18-2005   #3
RiceEatingZR1
RiceEatingZR1's Avatar
Default
NGK Plugs ROCK! I have never heard anything bad about them I have a friend that has them in his Firebird and loves them, I plan on putting them in my car when its time. as for the rapidfire plugs I have not heard anything good on them.
RiceEatingZR1 is offline   Reply With Quote
Old 08-19-2005   #4
Nick
Default
UPDATE.
Installed the Autolite double platinums last night, in stock heat range. Car runs fabulous. No detonation and coolant temps lowered slightly.
Its nice having my ZR-1 back again!
Old 08-23-2005   #5
ZR1 MK
Default
Good to here your car is running well again.
I use splitfire plugs without any problems.
ZR1 MK is offline   Reply With Quote
