Old 01-23-2009   #1
Bob G
Default 90-91Exhaust
Can someone post a picture of the early exhaust mainley the 3 bolt flange on passenger side .It seams stainless works does not know that there is a difference between the early & late . they sent me the slip on pipe for the passenger side [ 93-95 ] and said that is all I need For 91 Bolt up
Thanks Bob G
Bob G is offline   Reply With Quote
Old 01-23-2009   #2
Jeffvette
Default Re: 90-91Exhaust
Thanks Bob G
They do know. They shipped a 92 system to me for a customer with the slip fit on the passenger side.
Old 01-23-2009   #3
Bob G
Yes but I want the 3 bolt flange so the exhaust comes off easily Which comes on the 90-91 I don't know about the 92
Bob
Old 01-23-2009   #4
you want a picture of the cat-back portion?
or the header side..
I have an exhaust on the side of my house I should be able to get you a picture this weekend
Old 01-23-2009   #5
Bob G
Yes the connection points on both sides 3 bolt ball & socket & 3 bolt flange & gasket
Bob
Old 01-23-2009   #6
Jeffvette
Bob
The passenger side on 90-92 and 93-95 are all a slip on system. I've got factory manifolds for both currently. Only the driver side had a ball/socket system.
Old 01-23-2009   #7
Bob G
The factory manifold w/cat has a 3bolt flange that slips on to the pipe that comes off the cat witch bolts directly to the factory exhaust system. look at the factory exhaust it has a 3 bolt flange welded to the pipe that comes out of the resonator & is not removible unless you cut it off
Bob
Old 01-23-2009   #8
Bob G
Hey Pete Maybe you could help me out here!
Bob
Old 01-23-2009   #9
Jeffvette
Old 01-23-2009   #10
Pete
Pete's Avatar
This picture is a 90-91 exhaust you can see the driver side has the ball/flare 3 bolt flange and the passenger has 3 bolt flat flange.
SW's exhausts or headers do not come with the passanger 3 bolt flat flange no matter what year you order they're all slip fit.
If the slip fit has been on the car for a while it's a pain in the butt to take off, you have to beat the heck out of it to take it off.
The 90-91 design is much better and easier to work with and the pipe does not tapper down.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
