![]() Join Date: Jul 2004
This throttle body came with a motor I bought years ago and it has been on the shelf for a while.
It had a broken screw on the top for the coolant cover, and whoever worked on this not only drilled into the air chamber but broke the tap off in the throttle body. I removed the broken drill bit and then had a old friend that welded inside of the 2 screw holes to fill the damaged holes 2 were drilled out he then started to machine these areas but I had him stop where it is as you see it so if someone wanted a coolant bypass and a 63MM throttle body this is a perfect canidate. when you send it off to be machined for the 63mm bore any machinist could finish off the upper side I would have but I do not have a mill at my disposal anymore. I know I can make this a functioning TB so it is not trash and I will not give it away. Ill offer this piece of aluminum for $175 as you see it. ![]() ![]() ![]() ![]()
![]() ![]() Join Date: Dec 2003
Johnny, do you still have this?
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
I do still have it sent you a PM as well
