Old 08-15-2005   #1
bobbyhi
bobbyhi's Avatar
Angry INFL light
Well, here I am writing for help about the typical 1990 famous "INFL LIGHT". I have followed all of the instructions listed in the FAQ part of the ZR1Net but to no avail. I have cleaned both sensers and I still get the "16" code. I have done the grounding 'til I'm blue in the face. I even bought the clearing switch from Mid America and still nothing....Can't get the code to clear. Very frustrating to say the least. Maybe a bad senser or bad DERM???
Any suggestions would be very helpful.
Don't know where the L98 came from under the name and don't know how to change that either!!!
Old 08-15-2005   #2
zr1mom
zr1mom's Avatar
Default
The L98 is based on the number of posts you make here. Over time it will change from L98, to LT1, to LT4 and finally to LT5.
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 08-16-2005   #3
Jeffvette
Default
Check the yellow wire under the dash area for proper connection. Pull it apart and clean it with electrical cleaner. Then try to clear the codes.
Also when clearing the codes, it is very sensitive that you follow the intervals.
Old 08-16-2005   #4
bobbyhi
bobbyhi's Avatar
Default INFL light
Thanks Jeffvette - I'll give it a try tomorrow.............
Old 08-17-2005   #5
Lightbulb L98-LT1-LT4-LT5
ONCE U HIT 100 POSTS UR AN LT5
