Old 08-13-2005   #1
Bell Curve
Bell Curve's Avatar
Default Original Coolant for a 1990 ZR-1
What was the original coolant that came in a 1990 ZR-1. Was it the green stuff, or was it the red stuff? I've heard different stories as to which you should use, and that if your car came with one you should stick with it rather than change it. I know many GM cars come with the red-orange stuff now, but I wonder what was our original coolant.
Bell Curve is offline   Reply With Quote
Old 08-13-2005   #2
Kevin
Kevin's Avatar
Default
I use green in my car
Old 08-14-2005   #3
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
Default
I didn't even know there was a red coolant in 1990. I think the Dexron (orange-red) is a newer type of coolant. Mine has green as well.
Life's too short to be unhappy!
[IMG]http://i4.photobucket.com/albums/y128/koolaid117/Montage.gif[/IMG]
Jim Jones is offline   Reply With Quote
Old 08-14-2005   #4
Aurora40
Aurora40's Avatar
Default
There was no Dex-Cool in 1990. The cars came with the green stuff. However, you can use other ethylene-glycol coolants such as Dex-Cool. It won't have any long-life properties when used in a system that had green coolant, though.
I'd stick with the green stuff, except it's just about impossible to find. I ended up using Prestone Extended-Life stuff just because that's the closest to normal green silicated coolant I could find...
Bob Saveland
Former owner of #2517
Old 08-18-2005   #5
Nick
Default
I just use the green stuff, and change it every other year, while adding a bottle of Red Line Watter Wetter. Also, don't forget you're better off using distilled water for the lack of mineral content.
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
