Old 08-12-2005   #1
Question Primary Injectors
Can someone explain to me the difference of the early 90-91 versus 92-95 primary injectors? I saw some primary for sale on Ebay but it mentioned only applicable to 92-95 and was curious to the difference.
Thanks in advance for your assistance,
Old 08-13-2005   #2
Jeffvette
Default
Craig, the 93-95 injectors are all the same style. The 90-92 primary have the flange tip cut off, but the secondary injectors are the same style as the 93-95 injectors.. The injector housings are also different.
Old 08-13-2005   #3
Default
Jeffvette,
Thanks for confirming they are different. Just wanted to ensure I don't purchase the wrong ones.
By the way, I like all your avatars. I really enjoy them being deployed out here in the Middle East and it gives me another reason to check out the forum.
Old 08-14-2005   #4
Jeffvette
Default
Craig not a problem.
On the Avatar, I need to find a new one. I'll try to make it special for you.
Old 08-18-2005   #5
Nick
Default
Also, strangely enough, on the late model ZR-1's the primary and secondary injectors are the same, but carry a different part number, or so I've heard. Comments?
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
