Old 01-02-2009   #1
Default Finally changing to 4:10 gears......any other tips, tricks or recommedations?
Okay, I am finally getting to my differential and gears and looking for any thoughts of what else to do while I am under there. I am going to use the factory service manual procedures and drop the entire unit in my garage myself.
So far, I have:
- the complete kit with bearings, ring and pinion etc. that I will have a local shop r/r with stock unit
- speedo correction gears from Marc Haibeck
- C Beam plates
I will buy:
poly bushings and synthetic gear oil/w posi additive
Is there any thing I should look for other than the wear of tear of related items while I am under there or any recommendations from the experienced folks. This is my first time touching the differential, but I think I have all the tools needed for this job. My clutch is stock but fairly new so I'm not going to touch it yet. The 90 Z has 53K on it and the clutch only about 5K.
Thanks in advance and Happy New Year!
Old 01-02-2009   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Finally changing to 4:10 gears......any other tips, tricks or recommedations?
Be sure your bearing kit also includes the side yoke bearings and seals. A lot of kits don't. While doing mine I converted the carrier caps from 1/2" bolts over to 1/2' ARP studs. Here are the ARP Part Numbers:
4 x Stud - AR4.060-LB
4 x Hex Nut - 200-8607
4 x Washer - 200-8514
To order you have to call ARP Order Desk & Technical Support: 800.826.3045
You might also have a drain plug installed like in this pic while you have the case at the shop. Makes it a lot easier to service next time.
In case you are interested here is a pic showing the stock 3.45 ring and pinion next to a Viper 4.10 set and a Yukon 4.10 set.
The Viper gear set is quite a bit more substantial.
Old 01-02-2009   #3
jonszr1
jonszr1's Avatar
i would replace the 1/2 shaft u joints with the super spicer . bill b has the part number . just good ins also ck rear bearings
Old 01-02-2009   #4
Jagdpanzer
Jagdpanzer's Avatar
Denny's Driveshafts has 1350 kit for C4 aluminum half shafts:
http://www.dennysdriveshaft.com/p422...build_kit.html
Old 01-02-2009   #5
Thanks a lot, I really appreciate the input and recommendations. I'll definitely look into these; I might as well do it right the first time.
Old 01-02-2009   #6
I really appreciate the information and pictures; truly awesome and just like David said about getting your advice. I sent you an email.
Old 01-02-2009   #7
Jagdpanzer,
Thanks again and I guess you might have heard from ZZZZZR1 (David) that I have Yukon gears and this kit:
http://www.yukongear.com/ProductDeta...px?ProdID=2050
I guess I might have to consider getting some Viper gears?
I do have the drain plug kit from Corvette Clinic too; at the time I thought I was just going to install it and not change the gears.
Old 01-02-2009   #8
Jagdpanzer
Jagdpanzer's Avatar
Craig,
You can get the side yoke bearings and seals here:
http://ratech.stores.yahoo.net/coax84d44.html
Old 01-02-2009   #9
Craig,
Phil,
I really appreciate all your help and thought since I had a "Master Overhaul Kit" I was good to go. Thanks for the referral for the Viper gears too. Thanks for helping me do this right.
Big Mahalo and Aloha,
Old 01-07-2009   #10
James93LT1
James93LT1's Avatar
Craig,
You need help in dropping your rear end, let me know. Dropped mine a few times already.
James
James93LT1 is offline   Reply With Quote
