Old 12-20-2008   #1
TFENT
Default New Guy New ZR1 Owner Few problems Need Assistance
Hey all
So I was lurking around on here last couple of days as I was hoping on becoming a new ZR1 owner. Long story short found a 1990 Black on Black ZR1 sitting in a garage with 26K on the odometer. Owner had to liquidate it quickly and I made him an offer he refused. Few days later (today) he called an accepted the offer. Drove it home and parked it till daylight to see what I really bought.
Few observations and issues that need immediate attention. I have searched all over and have not found any solutions to these particular issues specifically. Thought maybe some of you could assist me with correcting these "issues". Not listed in any particular order:
Both headlights do not want to stay fully open
Prev owner states radio and A/C run together blows a fuse
I can't figure out how to get car in reverse gear. Saw him do it but was embarrassed to call and ask him if there was a reverse lock out.
The Low tire pressure light and the LTPWS light came on while driving home.
Other then that car is in very good shape. needs to be cleaned as i think it was stored in the garage and not driven in approx 3 years. It is going to the shop for a complete once over first thing next week but I want to drive it this weekend a little.
Any advice? assistance?
Thanks in advance.
TFENT is offline   Reply With Quote
Old 12-20-2008   #2
Jeffvette
Default Re: New Guy New ZR1 Owner Few problems Need Assistance
There are three little bushings on the inside of the motor that breakdown as they age. You need to replace them with either ball bearings, or plastic spacer bushings.
There is a shared line S214 that joins the head unit and the AC controller together behind the stereo. You need to get a service manual and start checking things out, or you need to see a pro in your area if you are not comfortable with electrical repairs.
There is a lift ring collar on the shifter. Lift up and it pulls a rod up. If the rod does not slid up, there is a small 3mm set screw in the collar that you tighten down to have it grab the rod.
Do check the tire pressure. Then go down to the nearest tire shop and remove the tire pressure sensors and throw them in a box.
Welcome to the insane asylum. Enjoy the experience.
Old 12-20-2008   #3
jonszr1
jonszr1's Avatar
you may have a bad sensor in one of the tires to light the ltpws.did you ck your tire pressure .the headlights could be bad nylon gears .can be got from mid america. they sell a rebuild kit. if you didnt get the factory service manuals with the car you need to get them .they are as thick as a bible . cant help on the radio airconditoning deal . welcome to the asilum . you will love this car . ps when cking the oil level do mit after the car sits overnight
Old 12-20-2008   #4
TFENT
WOW! Awesome guys!!
Where do I get the Headlight rebuild kit from? I am also installing HID's in the car.
If I chuck the TPS sensors will the light remain on or do I install new ones or???
Electrical: Will send to a stereo shop ASAP.
Rev: LOL you should have seen me trying to get it in reverse tonight. I looked like such an idiot that didn't deserve to be behind the wheel of a ZR1.
Where do I get the ZR1 bibles from?
BTW wait till you see a set of MovIt CER's installed on the car in a few months once they are made. Sneak peak...
Old 12-20-2008   #5
Jeffvette
All the major catalog companies will be more than happy to rape you for parts. You can get some nylon bushings from home depot.
Here is a write up from a ZR-1 owner
http://home.comcast.net/~zrjuan/headlight.html
No, the light will go out if all 4 are removed.
I would not use a stereo shop. Find a competent mechanic in Corvettes or at the minimum a car electrical certified shop.
www.helminc.com or ebay. There are three books, but two main ones.
Bank!
Old 12-20-2008   #6
TFENT
Bank!
On the brake system I am gonna cheat a little I own the USA/Canada distributorship of MovIt. The owner of MovIt in Germany also has a ZR1 in the toy box. He turned me on to this jewel.
Old 12-20-2008   #7
Jeffvette
I'll be talking to you.
Old 12-20-2008   #8
TFENT
Anytime my friend open 24/7 for brake talk/car talk/truck talk lol u get it. .
Old 12-20-2008   #9
Congrats TFENT on the nice low mile 90 score and welcome to the Zoo!
You may want to join this group too >>> http://www.blackcorvettes.com
Old 12-20-2008   #10
TFENT
All signed up just waiting for access. :P thanks !!
