Hello everyone,
I was wondering about the oil cooler on our cars. It looks relatively large but how good is it?? Is the pressure drop large? Also does it clean/flush nicely? My ZR1 is a 1990 and I am about to fire a new motor so I dont want any issues from the original oil cooler. Are replacements available?? Does anyone have any experience with aftermarket units? I dont think there is that much trash/gunk is mine but Id like to be safe. |
#2 | |||||
![]() Join Date: Dec 2003
Obviously I don't have any aftermarket knowledge, but unless your oil cooler is damaged, I doubt the lines will be plugged, but may have some gunk similar to the engine, if any.
So, tell us more about this new motor.
What did you finally put in? TomC "Crabs" |
What you will find is the aftermarket cooler is more compact, weighs less, and offers more mounting configurations than the factory piece. Since you are not running the LT5 anymore, I don't think you are worried about using factory components.
#5 | |
![]() Join Date: May 2005
Tyler |
is there a way to change the opening temp?
#7 | |
Tyler, he no longer has a LT5. |
#9 |
Where is this thermostat located? Is it in the actual cooler? It sounds like something I would remove but I dont remember seeing anything "funny."
I'm probably just being paranoid, but I like everything to be as perfect as possible. Nothing to worry about when I sleep. For the sake of an easy life I sold the BBC and used that $$ + the $$ from the LT5 stuff to build a SBC. Not just a SBC, but a nice one. Dart lil M, 406" SCAT rot as, MAHLE pistons, AFR 227 Elim, LUNATI solid roller, CROWER SS shaft rockers & lifters, MANTON pushrods (yes pushrods, but not just any, 7/16" to 3/8" single taper .120 wall), Super VIC, QFT 950. Im not exactly thinking of it as a step down from the LT5 in performance or durability. It should put a smile on my face. I still have some details to work out but Im hoping that by the end of the year the car will be done. One of the big ?s Im struggling with is what to do about the thingy thats gonna be sticking out of my hood. Scoop? Open? Cowl? just no time to think about somkething like that. |
#10 |
