Old 12-04-2008   #1
WydGlydJim
WydGlydJim's Avatar
Default Under plenum pics of a '90 just for reference
Thought someone might be able to use these. And what it should look like when you are finished!
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 12-04-2008   #2
billybaloneey
billybaloneey's Avatar
Default Re: Under plenum pics of a '90 just for reference
The one section pictured...before and after...cleaned up nicely...good job.
billybaloneey is offline   Reply With Quote
Old 12-05-2008   #3
It might be the angle on the pics,
but those secondary vacuum canisters look like
they need to be flipped around. The lever looks
like it's should be on the other side closer to actuator lever.
Old 12-05-2008   #4
WydGlydJim
WydGlydJim's Avatar
As far as I know, the plenum had never been off, but i can't say that for any real certainty, just going by what it looked like when pulled, and I did not pull the actuators. However your question led me to do some digging around. They are at a kind of wierd angle, but I did check operation, and it was fine, and I found this pic, that shows roughly the same strange angle. They are not in line with the butterfly actuators, but rather at an angle. Course the angle is a little more drastic on my pc, maybe it is on backwards heck I don't know.....Wierd
2009 LS9
1973 LS4/sold
Old 12-05-2008   #5
jonszr1
jonszr1's Avatar
the angle on both my zs are the same . and they operate fine , but it allmost look that if they were turned around they would hit ? does anyone know for sure or have pics showing what they should look like .?could they have been installed wrong at the factory
Old 12-05-2008   #6
Dandy97
Dandy97's Avatar
The first time I removed the plenum I found mine were like the ones shown. This is supposedly flipped. I flipped mine around and checked them with a vacuum pump and they no longer actuated properly. I reinstalled them incorrectly and they tested out fine, so I left them. I think if they have been backwards for a long time they should be just left alone.
Dandy97 is offline   Reply With Quote
Old 12-05-2008   #7
When I first pulled my plenum, I found mine in the same shape as your original pic. I flipped mine around. They were fine. Someone like Jeffvette or Pete ZR-1 could chime in but I recall reading another thread sometime ago on the orientation of the canisters.
Old 12-05-2008   #8
Jeffvette
The issue I believe was initially reported by Gordon K I believe. The issue is the actuators are installed upside down or 180 degrees. The arm is not in a correct line to be drawn back into the canister. The problem is, after being installed in that position for 18 years, that the rubber diaphragm has been reformed to the incorrect position. If you mount it correctly using an original actuator, you run the risk of severe binding and not being able to open.
Only when you are replacing with a brand new actuator, should you install it in the correct position.
Old 12-06-2008   #9
detch
detch's Avatar
here is a pic of my 95, looks the same
detch is offline   Reply With Quote
Old 12-06-2008   #10
Jagdpanzer
Jagdpanzer's Avatar
Are these secondary vacuum actuators still available and where is a good place to buy them reasonably?
