Old 12-03-2008   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Quest for Stronger Rear Spindles
Since I twisted off a rear spindle on my very first attempt at drag racing my Z a couple of weeks ago I have been looking into finding a more rugged solution to this obvious weak link component in the C4 drive train. In my search I’ve come across a pair of these custom made billet spindles specifically for C4 Corvettes. Unfortunately the seller has no knowledge about the original manufacturer however, he does claim though that they are machined from 4340 billet stock and much stronger than stock C4 spindles.
Has anyone here ever seen these spindles before and do you know the story behind them?
Old 12-03-2008   #2
Jeffvette
Default Re: Quest for Stronger Rear Spindles
Most of the places I know that made these have since gone out of business.
Try Tom's Differentials.
Old 12-03-2008   #3
I have a set of these. Bought them back a few years ago. They are supposed to be made of 4340 material.
Try Summers Brothers Racing (Rafael was his name) for the 31 spline / bearing conversion setup.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 12-03-2008   #4
Aurora40
Aurora40's Avatar
Hey Phil,
Is it possible you just had some bad luck? All I mean is there are presumably people throwing down more power with more grip (especially as you went on a grip-unfriendly 40 degree day) on stock ones with no issues. Maybe some stockers would last just fine?
Bob Saveland
Former owner of #2517
Old 12-03-2008   #5
Jagdpanzer
Jagdpanzer's Avatar
FU2,
Are you running them now on your big 441 incher and how are they holding up?
Old 12-03-2008   #6
Jagdpanzer
Jagdpanzer's Avatar
I called Summers Brothers and spoke with one of the new owners Jose Pontifes.
Here is what they can do:
SUMMERS BROTHER RACING
KIT # DESCRIPTION COST
409200 1986 – 1996 C4 CORVETTE HEAVY DUTY AXLE KIT $1,300.00
COMPLETE KIT INCLUDES:
2 HUB BEARINGS MODIFIED TO TAKE A 30 SPL SHAFT.
2 SPINDLES MODIFIED – REMOVED THE SMALL
STOCK STUB SHAFT, THE YOKE WILL BORED
OUT AND BROACH TO 31 SPLINE.
2 300M STUB SHAFT HEAT TREATED FOR STENGTH
AND DURABILITY PRESSED INTO THE YOKE AND WELDED ON THE BACK SIDE TO CREATE A HEAVY DUTY SPINDLE.
409201 1986 – 1996 C4 CORVETTE HEAVY DUTY AXLE KIT $920.00
(Hub bearings and stock spindles must be provided by the
customer and we will modify.)
Old 12-03-2008   #7
Zr1 Destroyer
Zr1 Destroyer's Avatar
I got a set from Tim at LPE about two years back......maybe try them!
[IMG]http://i43.photobucket.com/albums/e396/ry368/Zr1launch/Goodfellas-1.gif[/IMG]
Here, let me help you with your Vette...lol!
[B]1991 QuAsAr BlUe Zr1 w/415
1967 Nova w/Sb2 power!!!
1991 GMC Syclone
[/B][FONT=Century Gothic][COLOR=blue]
[/COLOR][/FONT]
Zr1 Destroyer is offline   Reply With Quote
Old 12-03-2008   #8
Pete
Pete's Avatar
Originally Posted by Aurora40 View Post
Hey Phil,
I have seen a set of those they broke first attempt at the track didn't even get one run.
I would suggest save your money and stick with stockers just don't do anything silly with them.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-04-2008   #9
FU2,
Never installed them. No need too.The stockers are doing fine in the 441
Pete
IF I were to change over the rear to anything it would most likely be to a solid axle. The complete solid axle conversion can be had for @ 5K and just about bolt right in.
Frank Urbo.
Old 12-04-2008   #10
A1990
A1990's Avatar
I know that last summer when Mike Ebert was first tracking his 427 he had billet spindles. Snapped them on the first run.
Changed back to stock ones and all is fine. He was running slicks and doing 5500 RPM launches.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
