Old 08-05-2005   #1
bike01
Wink How do you remove the pins from the ECM plugs
Can anyboody tell me "IN DETAIL" how to remove the female pins in the ECM plugs that connect to the back of the ECM.
I've been having some idle problems and when I 'jiggle' the wires on the back of the ECM the problems go away, at least for a while. I want to check them for corrosion and insure the harness wires have a good connection to the female pin.
I don't want to damage the connectors.
bike01 is offline   Reply With Quote
Old 08-05-2005   #2
Tyler Townsley
Default
Are you talking about the connector pins or the pins on the ecm. The pins on the ecm are fixed but the pins in the cable can be removed with a tool.
Tyler
