Old 11-01-2008   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Leaky Transmission Output shaft Seal
Just confirmed a small oil leak back at the transmission output shaft seal.
I understand this seal is common with other GM transmissions under PN 10140538. To get at it the drive shaft and exhaust will obviously have to be removed. Does anyone know if the seal can be replaced without having to unbolt the transmission tail housing?
Old 11-01-2008   #2
zr1don
Default Re: Leaky Transmission Output shaft Seal
I replaced mine when I had the trans out. The driveshaft must be removed & the seal can be r&r'd. Make sure the trans surface the seal sets in is clean befor installing the new seal.
zr1don is offline   Reply With Quote
Old 11-02-2008   #3
janozr1
Can you get this seal separetly or still just in kit ?
janozr1 is offline   Reply With Quote
Old 11-02-2008   #4
Jagdpanzer
Jagdpanzer's Avatar
Picked up a new PN 10140538 seal at the local Chevy store and put it in today.To get at it I had to remove the Corsa exhaust (the flex joints I added sure make removal and reinstallation easy), unbolt the C-beam, and pull the drive shaft. Bill Boudreau sent me a note confirming that the transmission extension housing did not have to be removed to replace the seal (thanks Bill). I was able to pry out the old seal using a small pair of end cutters and a flat blade screw driver. The old seal was somewhat brittle and a 1/2" section appeared to have become un bonded from the outer shell which was the source of the leak. The new seal drove in without a hitch. Put it all back together, topped off the transmission oil level and took it out for a short test drive. So far every looks dry with no sign of oil leaking past the seal. Total repair time was about three hours.
Old 11-02-2008   #5
HIZNHRZ
3 Hours! Heck that would be a weekend project for me.
Old 11-02-2008   #6
Jagdpanzer
Jagdpanzer's Avatar
Having a 4 post lift, pnuematic ratchet and impact wrenches sure help make the job go easier.
