Old 10-24-2008   #1
Default Donor Car for my spare motor
This would be interesting to drop the LT-5 in...
http://cgi.ebay.com/ebaymotors/Chevr...mZ170273772242
92 ZR1
#234
Old 10-25-2008   #2
Aurora40
Aurora40's Avatar
Default Re: Donor Car for my spare motor
That would be awesome! A ZR-1 'vert would be badass... Looks like you'd need to find one of the Z digi-dashes though.
Old 10-25-2008   #3
Bell Curve
Bell Curve's Avatar
Question Re: Donor Car for my spare motor
Is the history real and verifiable?
Bell Curve is offline   Reply With Quote
Old 10-25-2008   #4
Outside of a new wiring harness, trans, shaft, and Dana swap. What else would we be looking at for the conversion?
92 ZR1
#234
Old 10-25-2008   #5
hmm
I thought the car built for Don was a Wide body.
that on in the link is a standard narrow body Vert.. with an aftermarket ZR-1 looking bumper
Old 10-25-2008   #6
Here is Don Runkle's ZR-1 (DR-1)
Now look at the tail of the eBay one
that is NOT a wide body car as the seller claims
Old 10-25-2008   #7
Default Re: Donor: Nope
Not my cuppa tea; sorta piss poor "replica" IMHO. The problem starts with the rear: Tho the description claims that ZR-1 body panels are installed, it seems (to my eye at least) to be (at best) a valiant attempt at copying...but not quite making it (IMO). It may have some ZR-1 "looks like" trim e.g., rockers, etc, but it is easy to see at a glance (easy at least for us "Z" drivers) that it is an imposter! Then as Bob mentions, the dash, AND possibly the wrap-around cockpit of the Zs - was it used in '87?
It might have the license plate trim, but at the expense of the back-up lights - it does NOT appear to have the wider rear end, methinks. Looking at the aspect ratio of the tail lights, and again (to me) it is a obviously a bastardized attempt at mimicking the KOTH.
ON THE OTHER HAND... Beauty is in the eye of the beholder. So, trying to be objective now, if it looks good (and it does) authenticity aside, it might well be a fun project! (But...I cringe every time I see the ZR-1 badge on the bumper of imposters! Just MO, but then you did ask!)
P.
Old 10-25-2008   #8
Paul,
the Pre-90 ZR-1s, Prototypes, mules, Pre-production ones etc all had the Digital Dash, but were fitted with an upgraded tach that went to 8K
Old 10-25-2008   #9
Aurora40
Aurora40's Avatar
Huh, it sure looked wider to me, but that license plate thing is a dead giveaway.
I guess he basically says so right here:
From there, the body was fitted with ZR-1 specific panels including modified actual ZR-1 rocker panels, ZR-1 style rear bumper, ZR-1 tail lights and ZR-1 license plate trim.
ZR-1 style rear bumper, and nothing about doors, decklid, etc.
There are some ZR-1 'verts out there though. I've seen at least one at BG (not in the museum). I'd guess you start with a Z and make it a 'vert vs starting with a 'vert and making it into a Z?
Old 10-25-2008   #10
Bob did you see a yellow one? that began as a narrow body vert
