Old 10-22-2008   #1
Angry Antenna Mast Replacement
Well Its been one of those weeks. I have been stuck in training classes all week. As im heading to my office to grab my lunch the automated gate swing arm goes fritzy after reading my smart cart for entry and slams down the gate arm before my car fully clears. End result a rear antenna is almost completely snapped off however no other damage. How much is it going to cost to replace and how hard is the job to do to replace the entire antenna system? Thanks for the help GC
Old 10-22-2008   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Antenna Mast Replacement
Another case of magnetic sensors not respecting the fiberglass skin if our Corvettes?
Old 10-22-2008   #3
Jeffvette
Daryll, thankfully the access to the antenna is a lot better on the ZR-1 compared to the coupe. You can access everything just laying on your back in the garage. I have some mast kits on hand. 26.00
Old 10-22-2008   #4
Awesome I will give you a call.
Old 10-22-2008   #5
flyin ryan
flyin ryan's Avatar
they are not too bad to replace at all. i'm sure there is a thread on it here somewhere.
Old 10-23-2008   #6
Spoke to Jeff hes sending me a Mast kit said I could do it with not much trouble
Old 10-23-2008   #7
billybaloneey
billybaloneey's Avatar
I can't personally speak to mast replacement on the '90-'95's, yet, but it was relatively easy to replace the antennae motor and mast on my '85 coupe. Just remove the rear wheel and the wheel well cover, and you'll have plenty of room to work...plenty of room with respect to the amount of room a person usually has when working other locations of a Corvette. You'll also have the opportunity to do some cleaning/detailing in a seldom seen area.
Clint aka billybaloneey
'94 - C4 ZR-1 #445 - Black/Black
'05 - C6 silver/black 6sp
'85 - C4 white/graphite (almost done) automatic
'78 - C3 silver/black (a work in progress) automatic
billybaloneey is offline   Reply With Quote
Old 10-23-2008   #8
flyin ryan
flyin ryan's Avatar
don't have to remove the wheel for just mast replacement. can all be done from up top.
Old 10-23-2008   #9
Jeffvette
Even if you were replacing the whole antenna system, on the ZR-1 you don't have to remove the wheel or the fender liner. You have enough room accessing it from underneath the car in the rear.
Old 10-23-2008   #10
Jeffvette
I've had to remove a couple, because the ribbon had broken off inside the motor.
