Old 10-18-2008   #1
Chris_32212
Default Is anyone using Royal Purple?
i am curious if anyone uses royal purple in the motor. swapping to synthetic trans and diff fluid can net some hp and i am just curious if anyone has done it. the GM part number for our trans fluid cross references to Royal Purple 5w30 XPR fluid (Extreme Performance Race). they also have a comperable synthetic gear oil. i talked to Bill B. and he said he didn't reccomend royal purple in the ZF trans simply because he doesn't have any experience with it. he gave me a part number for a german made trans fluid that is only available at BMW dealerships and he raves about how good it is but i am curious if it provides the HP gain that royal purple probably does. i know we are only talking a mabey a few hp for just the trans fluid but hey, every little bit helps right? let me know your thoughts on this.
Chris
Old 10-18-2008   #2
PhillipsLT5
PhillipsLT5's Avatar
Default Re: Is anyone using Royal Purple?
stay with bmw trans fluid
see
www.zfdoc.com
Old 10-18-2008   #3
Chris_32212
i already know that thats the popular fluid... im not saying i am going to use royal purple. i just want to know if anybody has.
Chris
Old 10-18-2008   #4
I can not comment on the oil as I've been a M1 10w-30 + Zddp, BMW TWS 10w-60 trans, GM stuff + 2x GM additive in the gear guy in my 90 for five yrs. Prior to that the orig owner just changed the motor oil & coolant. He only put 7400 miles on the car in 14.5 yrs so he never messed with anything else.
The one thing I can say is there have been the odd thread here and at CF about the use of other trans fluids and failures. I can't say that you can find any direct links to the failures and the oil used.....but it's just curious that all the failures seem to just have one common factor....which fluid was used. Now, I say "seem" because I've never read any of those threads about ZF failure where any other contributing factor was mentioned. You know like I've never seen any one post up that they neglected their clutch hyd. system, or that they drag race and don't use the clutch to shift, or that they road race and use the zf like a crash box, or that the C-beam was out of alignment, or any other factor that would account for a zf failure. The only two, well three if you count customer abuse, reasons for zf failure that I've seen posted about are: I didn't use the GM or the Castrol/BMW stuff, and reverse/sixth gear welded itself to the output shaft(?). I'm not clear about what exactly is with sixth/reverse....something about an internal lack of oiling as a design flaw from the factory????
I'm just saying in my 5 yrs of being a member of the registry this is what I've seen posted up about zf's and failures. The only other thing that I know for sure is that in the second owner's manual (the one in the pizza box) it says that if you are going to "drive your ZR-1 enthuiastically, you should switch all your fluids to synthetics.". That is in my 90's other owner's manual....at the time I know that the OEM fluids were all non-synthetic fluids.
Okay, I'll admit another thing.....I can't afford to have a trans failure, or any other major failures, so I use what seems to be the popular lube that seems to have no premature failures associated with it. My brain tells me that even with all synthetic fluids in my 90, I would only realize any performance gain if I put the car on a chassis dyno. Driving it on the street I'm sure my 'butt dyno' wouldn't know the difference, JMHO on the performance gains part. I use the synthetics because I think they protect my drivetrain better than dino based lubes, again JMHO.
Old 10-18-2008   #5
Aurora40
Aurora40's Avatar
I would bet most of us use synthetic motor oil, trans fluid, and diff fluid. It just doesn't generally happen to be Royal Purple for said fluids.
And I agree with Tom. Personally I'll go with the safe play vs the one that isn't. Even though something else may work just fine or better. So for now it's Redline oil (full of ZDDP yumminess), Castrol trans fluid, and Mobil 1 diff fluid. I keep thinking I should go to M1 high mileage engine oil, as it has the "normal" amount of ZDDP and is cheaper, but something about that "high mileage" in a 40,000 mile car that I can't explain bugs me...
Old 10-18-2008   #6
jonszr1
jonszr1's Avatar
i have 4000 reasons to use the bmw 0-06 that bill recommends. i had the 6th gear reverse weld problem in my blk car. if i lose a few hp to not have 4000 dead presidents leave my pocket again its good by me
Old 10-18-2008   #7
jonszr1
jonszr1's Avatar
opps it castrol 0-60
Old 10-18-2008   #8
PhillipsLT5
see
www.zr1specialist.com
for motor oil
Amsoil 10/40
Old 10-18-2008   #9
Chris_32212
is the castrol and BMW trans fluid synthetic? i would venture to guess that it is but does anyone know for sure?
Chris
Old 10-18-2008   #10
Aurora40
Aurora40's Avatar
Chris
Yes, it is synthetic.
