Old 10-17-2008   #1
Exclamation SPAL FANS A NON INSTALL STORY
Hello I am posting this for Technical assistance for all forum members. Here is a cut and paste of the email I send to another forum member on a future SPAL fan install I was planning to do
I wanted to close the loop on this one. I finally received the fans which took a while as a factory direct ship and ended sending them back to MADVET a few days after they arrived. They arrived with no instructions a bag of bolts and two "mounting brackets". While the ad from MADVET states these are a direct replacement which to me means fits in OEM holes once you remove the factory shroud and fans It would be more correct to say they are an alternative replacement.
Both mounting frames in no way shape or form mount directly as a direct replacement. I called MADVET for assistance from their technical folks and they could not help me as they had never installed the fans on ANY C4 before. Nor did they have any instructions for the install. Nor could they find any online from the vendor.
They suggested I call Dewitt's who sells these fans which was the factory direct shippers. The fans are indeed Larger, Heavier and made in Italy. They are identical fans bolted together side by side. The only direct replacement item on them was the two electrical connectors. Dewitt's when I called never returned any of my phone messages as they were in the process of moving their operations.
MADVET tried to help but admitted hey it was beyond them. I said at my age without instructions on my DD I was not going to figure it out for them so they agreed begrudgingly to a full refund including shipping as this simply was not my problem. I had to get supervisors at MADVET directly involved to get the FULL refund.
Could I have installed them? probably but they would have looked like a cobbled in monkey butt add on item. If they were truly a direct replacement I would have installed them without hesitating. Now that I have replaced the radiator with and OEM replacement, Installed a new water pump and a set of Samcos (from the registry of course) and a stainless debris screen all my cooling nuisances have gone away.
I present this feedback to the brotherhood for anybody who was remotely considering the SPAL fan ugrade as their next project
Old 10-17-2008   #2
Default Re: SPAL FANS A NON INSTALL STORY
I have had good luck dealing with Tom at Dewitts. Tom's lack of response could have been a problem because of his moving to another building. He is running a special now through the end of the month at 10% off.
If you want try Tom again....business is in the out-house plus it is his "off" season.
Good Luck
Old 10-17-2008   #3
I agree the voicemail said that they were moving operations but I left a few messages and never received a return call. As they are not a true direct fit I will not be going any further with this project. If the brackets were redone for a true "direct replacement" I would take a look at the project again. The fans looked great but the mounting of them and the lack of any instuctions or technical support closed the door for me.
Old 10-17-2008   #4
Chris_32212
WHAT??? the instructions are always the first thing i throw away anyways. lol. jk. that sounds really frustrating. sucks when people providing parts or service dont have their shizz together. what made you want to upgrade the fans? just curious.
Chris
Old 10-17-2008   #5
The thought was while I was replacing the Radiator, The water pump and the hoses to go for a 4 punch combination to solve my overheating issues. As turned out the Radiator and waterpump were the crux of the problem.
The Spal fans did not show up for three weeks after doing that job so after verifying it would not direct fit I decided nah im not spending days figuring out multiple combinations to try and get them to fit. If they were a direct fit I would have installed them.
Old 10-17-2008   #6
Chris_32212
plus why put the time and effort into the fans if they aren't needed? Esepecially since it didnt' fit.
Chris
Old 10-18-2008   #7
PhillipsLT5
PhillipsLT5's Avatar
Stock fans just fine here in AZ
Fluidyne radiator, 180 stat, chip, runs way cool
Save your $
Old 10-18-2008   #8
Big D thanks for the heads up on the Spail fans.
Now I think I'll go with the newer/later mod. yr. OE stuff when I come to that point in my maint schedule. Those later fans are supposed to move more air along with having a better weather tightness to the motor cases.
Thanks for the post!
Old 10-21-2008   #9
No sweat Tom the intent was to advise any forum members who were considering the install in the future. I just wanted to point out what I found to be frustrating. The intent was not to slam anybody just advise as to what my "experience" was and potential pitfalls.
Old 06-14-2010   #10
pantera1683
Thanks,
You saved me from purchasing the SPAL fans I was considering before I read this thread. Does SPAL or anyone else make higher cfm fans that will replace the stock fans and fit into the stock fan shroud?
pantera1683 is offline   Reply With Quote
