anybody have information on which chip would be best for different applications? for example, i bought a genaric prom from exotic muscle that claimed a modest 12hp gain. but i have headers, B&B exhaust, and a light weight fly wheel. also i have heard of people programming their own chips??? is there some information on this somewhere?
Chris |
marc haibeck
![]() ![]() Join Date: Dec 2004
![]() ![]() ![]() Join Date: May 2007
Or Doug Rippie Motorsports http://www.dougrippie.com/
Dont forget to add the power key is always on function. Also Xfirez51 a member here called Dom has been know to play with the chip table values a little.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 10-15-2008 at 01:27 PM. |
![]() Join Date: Aug 2006
i did my own for all my cars, Chris. i can help you out, if you need, but your probably better off going to Haibeck, not many better, closer to you anyways. i'm flat out building engines these days, PROM's aren't my main gig, ya know.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
![]() Join Date: Dec 2003
There is a lot of info in this thread regarding chips.
http://zr1netregistry.com/forum/showthread.php?t=852 ![]() |
#7 | |
You should start here if you are really interested in learning. http://www.thirdgen.org/techboard/di...uide-book.html My car went through the same "evolution" yours has. Prior to P&P earlier last winter, I had put Watson's, Fidanza and B+B exhaust so I could have a calibration that would be compatible BUT, all tuning is a compromise unless its done specifically for your car using datalogs scanned on your vehicle. The fact that you're in Utah suggests that, due to "thinner air", your motor operates in different areas of the VE and SA tables mine does. |
