Old 07-31-2005   #1
bigd
bigd's Avatar
Default Service Engine Soon Light
The other day when coming home my '90 Z almost stalled when coming to a stop. This morning when I started it (and it took much longer than normal to crank) the SES light came on after 30 seconds or so of idling. It is throwing two codes; 45-Left oxygen sensor voltage was over 0.75 volts for 30 seconds when the throttle angle was above 4% during closed loop operation. 65-Right oxygen sensor voltage was above 0.75 volts for 30 seconds of closed loop operation when the throttle angle was above 20% or below 2.7%.
I don't think both sensors would go bad at the same time. Is there something that could cause both sensors to give these readings?
Thanks, Don
bigd is offline   Reply With Quote
Old 07-31-2005   #2
Kevin
Kevin's Avatar
Default
Did the car backfire under start up recently?
Old 07-31-2005   #3
bigd
bigd's Avatar
Default
No, But I checked the MAP sensor vac hose anyway. Still attached. Any chance stale fuel could be a problem? It's been 6 1/2 months since last fueling.
Old 08-01-2005   #4
bigd
bigd's Avatar
Default
Think I found the problem. Leaking injectors. The oil on the dipstick smells of fuel. It just seems strange that it would happen on both the left and right sides at the same time. Any recommendations on replacement brands or just stay with stock?
Old 08-01-2005   #5
Z Factor
Z Factor's Avatar
Default
While RC's are a good choice, if you are only going to replace the faulty ones, you would be better off sticking with matching injectors since they have different flow rates. I recently replaced one of my injectors rather than have the expense of replacing all 16. However, had I replaced them all, RC's would have been less expensive.
Good luck
Old 08-02-2005   #6
bigd
bigd's Avatar
Default
Z Factor, I agree. If only replacing the faulty ones (the codes tell me I have a rich problem on both sides), stock would be the way to go. But I'm leaning towards replacing all while I'm under there. On a 15 yr old ZR1 could I expect some others to crap out soon?
Old 08-02-2005   #7
Tyler Townsley
Default
As a final check you should check the fuel pressure. If it bleads down after turning the car off then you got a leaker. You can probably tell which cyl by pulling the plugs, the leaker should be apparent.
You might try some injector cleaner as it may be because of a bad tank of gas.
Tyler
Old 08-02-2005   #8
bigd
bigd's Avatar
Default
Thanks Tyler, It was on my list today to look for a fuel pressure gauge at one of the auto parts stores. Please expalin a little about the possiblity of bad gas causing the leak. The car has sat for about 6 months with 1/2 tank. (I was unable to get to the car to run it). No problems with the first 1/2 tank of gas though. Could it have gone bad setting for so long? Does it seems strange that both sides are runnning rich?
Old 08-02-2005   #9
Tyler Townsley
Default
THe stock injectors are very sensitive to water and just a minute amount will cause them to leak if they sit for any length of time. Depending on the amount of contamination injector cleaner can free them up. Old fuel can also cause problems and usually can be identified by a sour smell while the car is idleing.
Tyler
Old 08-02-2005   #10
Kevin
Kevin's Avatar
Default
If you can afford it change out all 16.
