does our car has indows fuse? if yes where is located?
thanks. |
![]() Join Date: Feb 2006
I think the fuses are in the panel on the right side of the dashboard. But I'll bet you have a window motor failure....
Ask me how I know.
I Dont see "power window " fuse there.
i guess ,it could be with Headlight motor Circuit breaker?!! ![]() |
I'm wrong - there is no fuse. Sorry. The power windows operate off the delayed accessory bus which has a 30 amp circuit breaker protecting it.
What is the problem you are seeing? Does one window work OK?
gbrtng,
The driver side window faild to work! the right side work OK!! I restore and repaint door panel, since the kid remove it and the car Door were repaint too, so i dont know what mistake He did during work ! ![]() Last edited by HADI-ZR1; 10-16-2008 at 06:00 PM. |
#6 | |
Glenn
the connector and switch and wire all ok , and the power already feed wires!
I believe there is a fuse under the passenger kick panel. There are 8 of them there. I shorted one removing the switch from the panel once.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
#9 | |
Replace the entire regulator assembly instead of just the motor. (To replace just the motor, you have to disassemble the entire regulator to replace one of the motor attachment bolts. It's not worth the effort.)
