10-13-2008 | #1 |
Wanted, Correction gear for 4.10's
I need a correction gear for Dana44 4.10's .
Also Radio Bezel for 1990 ZR-1, this is the radio and power key surround. Thanks.
Blck/Blck 90 #1799 |
10-13-2008 | #2 |
Re: Wanted, Correction gear for 4.10's
Check With Marc Haibeck.. He had the Speedo gears at one time
10-13-2008 | #3 |
It takes (2) plastic gears.
One you can get from the dealer, easy and cheap. The other gear I got from Lingenfelter, not cheap. I wonder if Bill Boudreau could help? Last edited by tf95ZR1; 10-13-2008 at 05:50 PM. |
10-13-2008 | #4 |
Us hot rod guys deal with this all the time. It can be a pain in the ***. Not too bad if the tire size and gear ratio are normal. If not, I recently saw a product the uses GPS to send a signal to the computer for the vehicles speed. Probably not much use to you but I thought I would mention it.
10-14-2008 | #5 |
Thanks for the comments guys, I'm always willing to learn about new products. I know Marc Keeps the gears but thought I would try other owners first to save any parts on shelves going to waste. If anyone has the correction gears sitting around then I'm a buyer.
Regards.
