10-10-2008 | #1 |
need to buy hose crankcase baffle
where is the best and fast way to buy them ??(need EUROPE shipping) Are they from same material like watter -radiator hoses ??
tnx for replys regards,Jano |
10-10-2008 | #2 |
Re: need to buy hose crankcase baffle
Try asking Phrogs,A26B (Jerry) or Ron Hasselman,Jeffvette. One of them should be able to help you out.
10-10-2008 | #3 |
Yes those crank case cover hoses are just radiator hose. I think they are the same size as the upper radiator hose on the LT5.....I think?
10-11-2008 | #4 |
yes they are the same size , just asking if is the material same for hot watter or oil steams.
10-11-2008 | #5 | |
It's a tight bend and the OEM hoses are "Pre-formed hoses"....I would think that with maybe some heat one could get the bends close enough....all ya need is for the hoses not to close at the bends.
