Old 09-28-2008   #1
Default Dumb*** move of the day
Have not had the Z out for 3 weeks. I was geared up this morning, going to run a few times at the track after putting the new injectors on.
-Helmet check
-sockets-check
-torx head screw drivers-check
-pen-check (the guy at the tech inspection hates it when you don't have one)
I hit the road, well over 1/4 tank of gas, and meeting Dominic at a BP so I will just top off there. I get about 7 miles, car starts to chug, then dies. I get out, check things, everything is plugged in, etc. The car will start and idle but dies after a few minutes. It cannot drive and dies when under load. I get in the car and listern.....I can barely hear a fuel pump.
-No codes
Call the tow truck.....I let them know that they can find me on rte 47, right across from the Mobile Gas Station.
-$100 to tow it back
After a few calls, I decide it must be the primary fuel pump. I replace the pump and go to put the assembly back into the car.......uhhhh......the tank is empty. I pull the assemly out, the float seem to move without obstruction....I put it back in and go an turn on the car.....
Tank shows as empty!
Nuff said.......day ruined.
Lessons Learned:
1) Always start with the obvious even when it seems to not be possible.
2)There isn't a-"No Gas" code
3)If you drive your car more you'd probably notice that the gas guage was not right.
92 ZR1
#234
Old 09-28-2008   #2
Default Re: Dumb*** move of the day
Although the Fuel pump would have cost less then a tank a gas
Old 09-28-2008   #3
Talking Ooooooh yeah.....
I've done similar, Lee. Now I don't feel so bad!
But, anyway, you get today's
DOH!
Prize!!
Old 09-28-2008   #4
Which is why, 100% exactly the reason why I set the trip odometer at every fill up for that one phenomenal gas mileage week.
I would like to pass this $100 savings tip on you now!!!!!
Old 09-28-2008   #5
Towing car home after stalling across from a Mobil station= $100
New Auto Zone Primary fuel pump= $80
Finding out the whole reason was an empty tank of gas = PRICELESS
Old 09-28-2008   #6
HADI-ZR1
LGAFF,
Mine always show LOW FUEL even when i fill the tank , so i never had same as you did.
I ALWAYS Think i am out of fuel...so i fill it again.illusion??
Old 09-28-2008   #7
Autozone pump=free-warranty for dumb*** not looking in the tank first.
Technically, the fuel pump did not work........because there was no gas.
I did not have a low fuel light, tow truck driver even checked it before he hooked up the car....he said you never know...he see's it all the time.
92 ZR1
#234
Old 09-28-2008   #8
Toyvet1
Lee you are braver man than I am to admit it. I would insist that it was a pump.
Toyvet1 is offline   Reply With Quote
Old 09-28-2008   #9
i will have to blame the paint i have been huffing all weekend as I paint my garage, undoubtedly I have suffered irreversible damage.
92 ZR1
#234
Old 09-28-2008   #10
You and the BRIT are in the same CLUB now!!!
While driving around Beverly Hills in her new Mercedes convertible yesterday, Britney Spears (and an unidentified driver) ran out of gas and had to be pushed to a gas station by a few police officers. At the station Britney could be overheard telling the officers she didn’t know about the whole “gas thingy” because her normal mode of transportation runs on feed.
Who runs out of gas with a car like that? If she doesn't know the difference between a shirt and a dress she can't possibly have enough brain to fill up.
