Old 07-23-2005   #1
jdodds1111
Default No Secondry Power
Hi All
I've fitted an LT5 to an Ultima GTR it uses a Porsche G50 gearbox. The cars running well but the second thottles are not coming in.
The engine is 1990 and uses a seperate ESC module for the Knock sensor.
The power key has been earthed out.
There is no speed sensor as I can not fit one to the Porsche box so I get the assosiated trouble code.
I sometimes get a cam sensor code.
I don't get any vacuum or second injector codes so I think everthing is OK.
The engine pulls smoothly with no hesitation.
There are no indications of lean mixture.
The engine revs up to 7000rpm ok.
Can you help?
jdodds1111 is offline   Reply With Quote
Old 07-26-2005   #2
rkreigh
Default
what a cool project. I would contact Marc Haibec. if the ECM has any fault codes, often the secondaries are disabled. on a car that light, you really don't need them. you can revise the programming in the memcal, and just eliiminate them altogether and not hassle with them. on a car that light the loss of low end torq might even help you hook a bit better with a nice pay back in more top end.
the car will drive nicely when calibrated to run without them. I'm considering ditching them myself as there is a fair gain without them in flow and parts left out don't weigh or break.
the factory manual should help you trouble shoot why they aren't working and know what is required.
Old 07-30-2005   #3
jdodds1111
Default No Secondary Power
Thanks for that
Where would I get the Memcal re-programed
Old 08-04-2005   #4
ZR1 MK
Default
The info dont seem correct. You will get code 61 if the secondary system has a problem and will limit rpm.
I agree with Ron regarding the elimination of the secodary system.
Contact
Mike Ebert (mrcrowley)
www.acsvette.com
http://www.zr1netregistry.com/forum/...read.php?t=653
Marc Haibeck
www.zr1specialist.com
ZR1 MK is offline   Reply With Quote
Old 08-04-2005   #5
Kevin
Kevin's Avatar
Default
Need pics stat.
Old 08-05-2005   #6
Tyler Townsley
Default
Originally Posted by jdodds1111
Thanks for that
I would recommend Tod Pepmeier as he has the knowledge and skills to add/remove code needed by your setup. Not sure if he has the time as he has a real job too.
tpepmeie@yahoo.com
Tyler
