Old 08-26-2008   #1
HADI-ZR1
Default differential case issue, and Coil-over shock removel.?
Is there any way to weld the case where it break? see [pic]. or i have to change it all?
How to remove the Black Sleeve over shocks? by press or ...?
Old 08-26-2008   #2
Pete
Pete's Avatar
Default Re: differential case issue, and Coil-over shock removel.?
Hadi the rear end is very fixable.
The black sleeve should slide off the shock upwards might need rubber mallet to knock it loose.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-26-2008   #3
HADI-ZR1
Pete ,
so what Procedure and steps to repair this broken piece?!?
I alreday removed the shock from the black sleeve. I had this "Coil-over shock" from exotic muscle long time ago, i try to lower the rear , but no chance, cuz the spring height is 26 cm,and i screw it to the end! the gap between tire and fender still 2 inch!!
so by changing the spring height with 22-23 cm , will the rear lower more??
Pete , about the front strip 1991 bumper. I saw :
The front strip molding is fixed into the front bumper (1991-95), its not separated from the front bumper, same for the rear!
Old 08-26-2008   #4
Pete
Pete's Avatar
Is that Dana 44?
A piece of round aluminum stock weld and drill.
I would take it all apart and bolt each half on a steal plate.
Did somebody tell you it can't be repaired or it's junk?
I'll take that junk.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-26-2008   #5
HADI-ZR1
its not junk , its my ZR Dana 44 .
no one told me it cant be repair, Pete.
