Old 07-31-2008   #1
zr1343
zr1343's Avatar
Default General Maintenance
I changed the trans fluid with 10 tws 60 Castrol.
Replaced a leaking slave cylinder and bled in new clutch fluid.
While I am under there I will be replacing the rear diff fluid. I was thinking of trying redline but I think I read that you should not use the GM posi fluid with Redline. Use Redline friction modifier instaed. Anyone heard this ?
Whats the best rear diff fluid to use for a ZR1 driven on track days?
zr1343 is offline   Reply With Quote
Old 07-31-2008   #2
karterdon
karterdon's Avatar
Default Re: General Maintenance
Mobil-1 for the rear end. As for the Trans - I would have suggested - Amzoil - It meets the GM requirement - It is fully synthetic and you shift will be very smooth.
karterdon is offline   Reply With Quote
