![]() Join Date: May 2008
A new owner here, so forgive these seemingly simple questions.
I know that the rear end body parts on the ZR-1 are bigger than the standard C4...to accommodate the wider tires. 1) are the doors a different size? 2) are the rear side light housings a different size? 3) are the brake and turn signal lenses a different size? 4) are the backup lenses and license plate assembly a different size? 5) is the rear end carpet and internal trim a different size? 6) is the "CORVETTE" script a different size? 7) within the ZR-1 line, 90-95, were there any parts that changed size/fitments from year to year? In other words will the early ZR-1 body parts fit the late model ZR-1's Is there a list published anywhere that points out all of the differences between a ZR-1 and a standard C4...front to back? Obviously 75% or more of what's in the engine compartment is unique to the ZR-1. Other than the engine itself, what are some of the other items in the engine compartment that are ZR-1 specific? Thanks, Clint aka billybaloneey |
1: yes
2: no 3: yes 4: yes, not a different size but a different assembly 5: no 6. from the normal C4 yes 7: not that i'm aware of other then the rub strip. the ac compressor, rad, ecm, lines, belts... this is all as far as I know, and i could be wrong. Jeff you out there?
For #6 and #7, the "CORVETTE" emblem is larger on the '91+ models (of which non-Z's didn't have an emblem anymore). The 1990 has the same sized emblem as all '84-90 'vettes.
#4 | |
![]() Join Date: Nov 2007
![]() P. |
![]() Join Date: Jul 2007
I did not think the Brake and Turn Signal Lenses were a different size (#3)
#6 | |
![]() P. |
#7 | |
Reverse light ARE different though
Brake and turn signal lens approximate measurements are the same on my 93 Ruby (LT1) and on my 92ZR-1 Tail light/brake lens are about 6 1/4" wide by 5" high on both cars. Reverse lights measure 3" wide and 6 1/2" on both cars. Rear side light/reverse lights are 1 7/8" high and 10" long on both cars.
As far as differences in body panels go (within the ZR-1 line), aside from the belt moulding, as someone mentioned, the front 1/4 side covers are different. The 90 stands alone. The 91-94 are another style & the 95 are also stand alone. Last edited by 32valvZ; 07-19-2008 at 04:57 PM. |
#9 | |||||||
