Old 07-11-2008   #1
Kevin
Kevin's Avatar
Default twin turbo zr-1 dyno sheet...
does anyone have a copy of the ZR-1 STS turbo sheet they can post? I want to see the curve this beast has.
Old 07-16-2008   #2
RHanselman
RHanselman's Avatar
Default Re: twin turbo zr-1 dyno sheet...
It's actually a Raptor LLC system that STS has given their rights.
This is the 616 rwhp graph at 10 psi. The car is now running 12 psi and an estimated 675 rwhp.
Cheers,
Ron
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 07-17-2008   #3
Nice numbers. Do you have a pic of the latest install configuration? Was this run with your low compression LT-5 Ron? GC
Old 07-17-2008   #4
djpatrick35
djpatrick35's Avatar
That...Is....Amazing!!!
Hitting its power peak at 5,800 RPM?!! Awesome. I wouldn't trust myself in that beast because I'd always keep reaching for that peak!
djpatrick35 is offline   Reply With Quote
Old 07-17-2008   #5
Aurora40
Aurora40's Avatar
Hey, just a suggestion, but if you take it for another run, can you get them to start it at a lower RPM? It would be interesting to see the power <4,000 rpm as well.
Old 07-17-2008   #6
RHanselman
RHanselman's Avatar
Originally Posted by GOLDCYLON
Nice numbers. Do you have a pic of the latest install configuration? Was this run with your low compression LT-5 Ron? CG
I'll have some pic's latter and yes this is with the low compression motor...
Ron Hanselman
Founding Member #80
Old 07-17-2008   #7
RHanselman
RHanselman's Avatar
We haven't tuned her at the lower RPMs yet. Will do that after she returns from the Fabricators shop. We are having 10 production sets of pipes made. should be complete by the end of the month!
Cheers,
RH
Ron Hanselman
Founding Member #80
Old 07-17-2008   #8
Great numbers and some asphalt ripping torque. The sound is just sooo sweet.
Old 07-18-2008   #9
Polo-1
Ron it looks like you are shutting it down 63-6400RPM Have you run it up 7200?
Old 07-18-2008   #10
RHanselman
RHanselman's Avatar
No, we didn't have the larger fuel pumps in the time and the engine was only a few miles old... He had the limiter set at 6800.
Cheers,
Ron
Ron Hanselman
Founding Member #80
