Here is a small list. Ask if you need something that not listed yet. Motor and Trans are gone.
1991 ZR-1 LT5 Parts List Car was Red/Red with 61 k on it Rear view Mirror $25-Goldcylon Engine oil cooler…$25 -63vettezo6 Engine oil cooler hose….$150-Goldcylon Air Cleaner Assembly with K&N..$65-Chris Complete Dana 44 Conversion Kit…..$1800 Front Left sideTurn #16514491….$15-Goldcylon Front Right side Turn#16514492….$15-Goldcylon Rear side marker right#16508520..$15-Goldcylon Rear side marker left#16508519..$15-Goldcylon Front Fog/Turn left….$45 Front Fog/Turn right…$45 Reverse lights pair ………$25 Horns…..$15 A/C blend door#10158085….$10 Blower Motor……$15 Blower housing under dash…$40 Blower housing #52450785 engine side….$200 both parts-63vettezo6 Left and Right Gills panels……$40-DMark Hood Latches……$25-1991ZR1 Hood Latch cables..$25 Accelerator pedal…..$20 Accelerator/cruise cables…….$25 Emergency Brake handle ……..$25 FX3 shock controller rear set…..$60-Chris FX3 shock controller front set…….$60-kabnvtt Rear shock pair…….$75-63vettezo6 FX3 seat switches…..$30-Goldcylon FX3 computer…….$50-1991ZR1 Front shock pair(New)…..$150-63vettezo6 Upper Rad shroud(with stickers)…$50-63vettezo6 Coolant over flow……$10-dbriana Vacuum ball….$5 Fan Assembly………..$75-Chris Lower Rad shroud…..$10 Wiper motor……$10-xlr8nflorida Front impact bumper………..$40 Rear Impact bumper (ZR1)……$75-Chris maybe Rear bumper (no light/moldings)….$500-63vettez06 Master Brake cyl…………..$50 Battery tray………..$10 Upper coolant reservoir…..$15-dbriana Clutch/brake pedals…..$15-Gustav(brake) Cruise control bracket…..$10 Air pump Smog stuff…….$25-xlr8nflorida Left head light assembly (w/motor)..$50-1991ZR1 Right head light assembly (w/motor)..$50-1991ZR1 Driver side mirror…$45 Passenger side mirror…$45-jerrydirks Gas tank…..$25-Chris Evap canister&lines….$25 Borla 2.5 (mid pipes gone)….$200-Chris ECM bracket (small crack)….$5 Spare Tire Bag(bad zipper)….$25 Spare tire…………$25 Glove box tray(dash)…$5 Glove box door(dash)…$10-dbriana Head Light module….$40-1991ZR1 Inside wire harness (from dash/fuse boxes 2/relays/FX3/doors/seats/ABS/tail lamps) this was $1147 new from GM no longer…..$400 A/C dash vents………$5 ea.-dbriana (left side only)-xlr8nflorida the rest of dash vents Rear tail lights w housings …..$30-xlr8nflorida Instrument panel (Canadian)…..$350 Head light switch…….$25 DIC panel……….$20-xlr8nflorida Bose/CD and module ( unknown cond.)….. $75-webruke A pillar moldings……$5ea Power key switch/and bezel ( switch and bezel are epoxy together it works)…..$25-Goldcylon Brake Booster ZR-1/PBR ( gone from GM)..$200 Rear cargo moldings ……..$5ea-dbriana (right side only) Fuel door assembly…..$25-Falconfling Steering wheel (no air bag)…$50-Ifogot who Turn signal/wiper/cruise switch…$40 Jarvis Seats w motors and rails (no rips)..$500 falconfling The prices do not include shipping, I only charge what the shipping is( no extra ). So if you call it here it's yours. Please keep it out here what you want, Im getting PMed crazy. We can PM shipping and payment info. Thanks Kevin Last edited by Polo-1; 05-15-2011 at 04:56 PM. |
![]() Join Date: Sep 2005
I'm interested in the following
Hood latches FX3 computer Left headlight assembly Right headlight assembly Headlight module Power key switch and bezel Sending you a PM |
If the passenger side is considered the left side I'll take the left side headlight assembly w/motor!
I posted on the other forum at 156 pm as well and also sent you a PM
Ill take the switch and bezel ( Does it have a key?) Also I want both the front left and right side marker lights Also the rear side marker lights both sides Does the FX3 switch include the harness Please LMK Daryll
Also can you send me a pic of the upper radiator shroud with stickers
goldcylon@cox.net Thanks Daryll
Works great polo. Ill stick with what I have listed do you take Paypal? Daryll
Ill take the switch and bezel ( Does it have a key?) Also I want both the front left and right side marker turn signal lights Also the rear side marker lights both sides Does the FX3 switch include the harness
#8 | |
You are 1st for FX3/seat switches and harness not cut. and all side markers. NO WIRING WAS CUT FROM THIS CAR... All finger nails inplace, thank JeffVette for that..... |
#9 | |
http://forums.*************.com/show...post1566196278 First to Post with the same list http://forums.*************.com/show....php?t=2071343 First to post again about the same list
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 07-06-2008 at 07:55 PM. |
#10 | |
LOL ok I will I think I owe him a beer or too as well What will you need for shipping Im at $90 for the front and rear side marker lights and the FX3 switches with harness. I do not want the radiator shroud. Maybe the oil cooler lines if they are still available? Is the radio bezel surround avail Does the AC condensor come with all the ac lines as picd?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 07-06-2008 at 08:27 PM. |
