Old 06-02-2008   #1
kenthompson
kenthompson's Avatar
Default Good heavens it's loud.
Got the headers done and the 3" exhaust done.
Good golly, Miss Molly this thing's loud now.
Even if I close the baffles on the PE's it's loud.
Lost a minor amount of torque on the bottom end, or the C-Beam plates work that well, the rear-end doesn't kick out anymore.
Mr. Flint, get to work!!!! Scotty needs more power.
kenthompson is offline   Reply With Quote
Old 06-02-2008   #2
bradslt5
Default Re: Good heavens it's loud.
I had the same problem (tq loss0 until i had the inj housings and plenum ported then it got alot better .also rear end gears either 373 392 410 help in the tq loss a bunch
Old 06-02-2008   #3
kenthompson
I've got the 4.10s in it now. It will still bake the 315's, just not quite as vigourously as before.
I think it has more to do with the c-beam supports.
Jeff has my IH's and Plenum to do his work with. I hope by September?
Old 06-03-2008   #4
kenthompson
UPDATE!!!
This thing has LOTS of blowby. I'm seriously in doubt that it will pass smog on the "visable smoke test".
Could be a potential issue.
Heck, I may have to put the cats back on just to clean her up a bit.
Man does she sound good though.
Old 06-03-2008   #5
Sorry for the dumb Q's
where do you think the "blow by" is coming from? lack of valve stem seals on the exhaust side on our 90's? Can the better scavenging effect of headers really do that? It can't be the rings, can it?
I remember in the old days....back in the 60's & the 70's ......when a new exhaust sys was installed they used to smoke a bit for a little while till they were 'run-in'...
