06-01-2008 | #1 |
Oil Drain Plug
Looks like my oil drain plug has finally rounded off to the point that a wrench won't work. I've done some searches and have seen that NAPA sells a replacement, but can't tell if it works for all years.
Are OEM plugs no longer available, and if so, is there a preferred replacement? Thanks, Pat |
06-01-2008 | #2 |
Re: Oil Drain Plug
the napa plug will work for all years
06-01-2008 | #3 |
Re: Oil Drain Plug
Also if you want OEM, you might talk to WVZR1. He hooked me up with a plug and the gasket. The NAPA plug should work fine though. But their cardboard gasket, in my opinion, sucks...
Bob Saveland Former Owner of #2517 [IMG]http://a.random-image.net/aurora40/vette.jpg[/img] |
06-03-2008 | #4 |
Re: Oil Drain Plug
I got one from my local Chevy dealer about a year ago.
[IMG]http://www.c3vr.com/member_uploads/401_500/419/thorsten_norge.gif[/IMG] [B][I]Jim O. [COLOR=white]..............[/COLOR][IMG]http://www.c3vr.com/forum/smileys/smiley27.gif[/IMG] [IMG]http://www.c3vr.com/member_uploads/401_500/419/driving1.gif[/IMG] "[COLOR=red]The Toys[/COLOR]" [/I][/B] ...'90 ZR-1.......'70 roadster.......'78 Trans Am.... [I][B][URL="http://www.c3vr.com/member_uploads/401_500/419/TheToyII_102_852.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/TheToyII_104_65.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/TheToy.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/Itsa70_36a2.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/PICT3106a.JPG"][IMG]http://www.c3vr.com/member_uploads/401_500/419/PICT3106a_sig.JPG[/IMG][/URL] [/B][/I] (click on each to see a larger version) [I][B][COLOR=red]Save the Wave...!!! [IMG]http://www.c3vr.com/images/smilesani/wavey.gif[/IMG][/COLOR][/B][/I] |
12-27-2010 | #5 |
Re: Oil Drain Plug
Here's an interesting thread/vendor offering an alternative to the NAPA plug: http://forums.corvetteforum.com/c4-z...roduction.html
http://www.magdana.com/15201/index.html Last edited by ScottZ95ZR1; 12-27-2010 at 12:08 PM. |
12-28-2010 | #6 |
Re: Oil Drain Plug
I bought a bunch of the Magdana ones, very good plug, strong 'Rare earth' magnet. The copper gasket it comes with sucks horribly though, you can just about pull the threads out of the oil pan from tightening it & it will still slow drip. I made my own plug gasket out of Nylon. Wish I would have done it from the start...
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
12-28-2010 | #7 | |
Re: Oil Drain Plug
I just bought a couple of the plugs but haven't used one yet. I'll find something suitable before spring and trash their copper gaskets. |
12-28-2010 | #8 |
Re: Oil Drain Plug
try a search on www.jerrysgaskets.com for drain plug. I have 3 different styles of drain plug gaskets and all were used at one time or another on the LT5
