![]() Join Date: Mar 2008
Hi all,
Today was a terrible day. I had family in town and I was bragging about my Z. So I took everyone to the garage to show my girl and she would not start. ![]() |
![]() Join Date: Mar 2007
Could be a bad battery that won't hold a charge. I would replace, unless its new, or at least have it load tested at autozone, etc. To remove the battery, you need to remove the torx head screws lining the front fenderwell, as well as a large black bolt on the right side(on top) of the small panel that shields the battery. Gently pull back on the panel, to see if it is loose. Then behind the battery, at the base, is a battery hold down. REmove that bolt, you should then be able to then gently pull the panel back, and remove the battery.
LGAFF 92 ZR1 #234 |
![]() Join Date: May 2006
Sounds like it could be the battery.
Take a look at this thread for battery removal instructions: http://www.zr1netregistry.com/forum/...hlight=battery |
