Old 05-08-2008   #1
65ZR1
Default Quick wiring question.
I have 94 service manuals but i am troubleshooting a 90 system. Can anyone tell me what computer terminal the engine oil temperature wire goes to?
Thanks in advance
65ZR1 is offline   Reply With Quote
Old 05-09-2008   #2
368zr1
368zr1's Avatar
Default Re: Quick wiring question.
Here's the schematic from a 90 Preliminary manual so the color code of the wires could be wrong.
The temp. sensor has a 3 wire connector.
It appears the sensor is two sensors in one package. One sensor used by the temp. gage and the other one by the ECM.
Connector Pin A is a Black wire, is ground via the ECM Red connector pin 16
Connector Pin C is a Dark Green/White wire goes to the oil temp. gage
Connector Pin B is a Dark Green wire goes to the ECM Red connector pin 18
To verify the gage works.
Disconnect the connector at the sensor
Turn ignition On
Gage should read High
If that's correct
Ground Pin C of the connector (Dark Green/White wire)
Gage should read Low
368zr1 is offline   Reply With Quote
Old 05-09-2008   #3
65ZR1
Thanks for the info. Hopefully we can get it solved today. Its the ECM connection. The scan tool says the oil is -38 so the secondaries wont turn on.
