Old 05-03-2008   #1
UKZR1
UKZR1's Avatar
Default Scan data
Take a look at this scan data. left/right O2 cross counts are way different.
Not sure what I'm looking at exactly so over to those that do. The car was just at idle in the garage.
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 05-03-2008   #2
Default Re: Scan data
I can't answer your question but,
which scanner are you using for data??
Old 05-03-2008   #3
UKZR1
UKZR1's Avatar
Hi ya Jeff. Its an AutoXray EZ read 2000. It was supplied with only error code scanning. I had to pay and have the real time scan function and trigger functions unlocked. Data downloads to EZPC
I'm wondering if the oxygen sensor on that side is faulty. The mvolt reading was all over the place compared to the other.
Marc Haibeck 368
B&B, Brembos
DRM suspension
Old 05-03-2008   #4
Possible.. did you drive it to see where the O2 voltage was? idle is not always the best to use to gauge the O2
Old 05-04-2008   #5
UKZR1
UKZR1's Avatar
I'm not able to drive it at the moment. It has no front brakes!! Waiting for replacements from Movit
Done a search, cross counts is the speed of the sensor so one is really really slow. I'll have spare ones, I'll fit them and do a full data set scan next time.
Marc Haibeck 368
B&B, Brembos
DRM suspension
Old 05-04-2008   #6
Aurora40
Aurora40's Avatar
It could just be coincidence, but the left one is the one with the low x-counts. And it also happens to be the one right around 450mV when you took that snapshot. Generally they will be at a low mV or a high one, not really stopping through the middle. So it's possible the left sensor is lazy.
The values should flip wildly back and from from ~100mV to ~900mV really fast. I think it's also possible the cross-counts have rolled over? I don't think the value goes super high, sort of like an odometer without enough digits.
Have you noticed any drivability problems? If this is just at idle, I'd probably wait until it was drivable and see what happens in regular driving.
Old 05-04-2008   #7
UKZR1
UKZR1's Avatar
yes I think you are right the mv readings were rolling through very quick on at least one, I think both of the sensors. I will check agin but will record more than one frame of data.
As mentioned in another thread, I'm waiting for some new brake parts from Movit. while the car has been off the road I have been doing those odd jobs I never seem to get around to. I wanted to have a play with the scanner as I havent really used it much before and I also wanted to check for leaking injectors as well. Idle is sometimes not as smooth as it is other times and the car does drink a lot of gas. Though I realise its far from stock and that may well be down to me or my right foot at least
Marc Haibeck 368
B&B, Brembos
DRM suspension
Old 05-04-2008   #8
tpepmeie
Good point. The absolute number of cross-counts is irrelevant... The counter only goes up to 255, then begins again at zero. What does matter is how frequently/quickly it is crossing. You should see very rapid cross-counts in closed loop operation, and similar reactions from each side left/right. On a graph it will be a nice stairstep up to 255 on each side in just a few seconds.
Todd
