Old 05-02-2008   #1
jrd1990zr1
jrd1990zr1's Avatar
Default 1990 ZR1 oil leak???
I recently purchased a 1990 ZR1. Has about 43,000 miles. I noticed what appears to be dried out oil in the area below the oil filter. Any thoughts as to what this may have come from or was the previous owner just sloppy during a filter change. I don't see anything coming out around the heads, just in the front right corner.
Any ideas??
Thanks
Old 05-02-2008   #2
Jeffvette
Default Re: 1990 ZR1 oil leak???
Could be a sloppy owner when removing the filter, could also be a bad oil pressure sensor that has since been replaced.
Old 05-03-2008   #3
Z Factor
Z Factor's Avatar
I agree with Jeff as to the two most likely reasons. Get in there and clean everything up when you change the oil & filter and see if anything is leaking.
Old 05-03-2008   #4
jrd1990zr1
jrd1990zr1's Avatar
Thanks Jeff,
BTW you have my vote for best avatar.
Old 05-03-2008   #5
Jagdpanzer
Jagdpanzer's Avatar
Originally Posted by jrd1990zr1
Thanks Jeff,
Looks like she has more than she can handle and could use some help.
