Old 05-01-2008   #1
Default MEMCAL PROM ID?
so I drove the Zr-1 around the block a couple times.. it Idled okay at first..
then at 2K. must be a vacuum leak.. looks like Secondary circuit.. I think.
Anyway that is another post..
I pulled the MEMCAL out tonight and it has an orange handwritten label on says: 1990 ZR-1
any Idea who did this on their PROMs? I have a picture and will post it when I get it off the camera. Now how do I go about finding out the OEM broadcast code and which definition it is $8E or $8EA..
Thanks
Old 05-01-2008   #2
Default Re: MEMCAL PROM ID?
Old 05-02-2008   #3
Originally Posted by -=Jeff=-
Well its not a DRM thats for sure. His have White Label with a red DRM logo and a silver pen writing on the side for the year.
Old 05-02-2008   #4
I emailed Marc Haibeck a picture too.
it is NOT:
Haibeck
LPE
DRM
ADS
Z industries
Marc mentioned he thought it could be:
Morrision
Guldstrand
Corvette Consultant
Old 05-02-2008   #5
Thanks
Well if we downloaded the bin, the Mask ID should be there unless the checksum has been disabled, then it'll be an AA. as I said before, the diff between the original and the "A" Rev of the chip is in the 7XX addy area. Everyhting will line up before that point.
Brad's chip had the memcals like that, not the Knock sensor circuitry like mine. Do the 91s have the Knock circuitry or external?
Old 06-10-2008   #6
bradslt5
just read corey email and all he said was there was structure differences??????. i will see if i can get ahold of him tomarrow and get the low down
Old 10-28-2010   #7
been a couple years.. still no answer..
Asked SGC, it is not theirs either
Again, Marc mentioned he thought it could be:
Morrision
Guldstrand
Corvette Consultant
I know I guldstrand is around , how about the others?
Old 10-28-2010   #8
If Brad had it on his, was it on the Callaway? I assume they tuned cars
Old 10-28-2010   #9
Jeff,
There's an easy way to tell if its an 8E or 8EA. If you have a stock 8A bin, do a compare with the bin you download from this chip. If it tracks until about the 7xxx addy, then its an 8EA.
Old 10-28-2010   #10
Whether it is 8E or 8EA does not matter. I want to know who.made the chip
