Old 04-08-2008   #1
GRZR1
Unhappy Desperate Need Of Engine Oil Cooler Hoses!!
The high pressure engine oil cooler hoses on my 1990 ZR1 are leaking like a sieve. My local GM service mgr says that he can no longer order them from GM..
HELP!!!! Anyone know where I can get them???? They leaked on my first ZR1 but that was 4 years ago and I had no problem ordering them back then. I am at a loss......
GRZR1 is offline   Reply With Quote
Old 04-08-2008   #2
Default Re: Desperate Need Of Engine Oil Cooler Hoses!!
I know Kurt White Sells them, not sure who else.. a friend I know was sellign adapters too
Old 04-08-2008   #3
GRZR1
Thank you so much. I will get in touch with Kurt White. What is the "adapter" all about?
Old 04-08-2008   #4
Since the cooler line are unavail, there is an adapter to adapt to AN fittings ..
the assembly (that is KW) (With adapter)
http://cgi.ebay.com/ebaymotors/Corve...spagenameZWD1V
Adapter
Old 04-08-2008   #5
tf95ZR1
tf95ZR1's Avatar
I assume just like the high pressure power steering hose,
you can take your leaking hose with fittings to any competent
hose fabrication shop and have them whip you up a new hose.
My leaking rubber hose was replaced by a cool looking braided
metal hose and they used my old fittings. A FRACTION of the
new dealer price if you can even find them. Good Luck,
Ted
Old 04-09-2008   #6
Z Factor
Z Factor's Avatar
Hello and welcome to the forum.
Another source to try is
https://www.partszoneonline.com/index.php
Old 04-09-2008   #7
PhillipsLT5
PhillipsLT5's Avatar
Try a local hose & tube rebuilder
Old 04-09-2008   #8
SharkPilot
SharkPilot's Avatar
I converted mine to AN fittings and steel braid hose. When I get back home I can post a photo or two for you. I figured that steel braid would last much longer and would be more reliable too. They also cost less to build than replacement with the OEM style rubber hoses. If I remember correctly it was about $160.00 to have the hoses and fitting made up and then I installed them. Not only do they look nice but I feel confident that there will never be a leak there anywhere.
SharkPilot
SharkPilot is offline   Reply With Quote
Old 04-04-2009   #9
Durango ZR1
Just got the hoses from Kurt White. They went on easy and no more leaks. expensive, but hey, it's for a ZR1. No complaints here
George
Durango ZR1 is offline   Reply With Quote
Old 04-04-2009   #10
PhillipsLT5
Try Jeff Vett
