Old 04-24-2005   #1
Gasman57
Gasman57's Avatar
Default Looking for ZR-1 specialist
Hello all, I live in south central Pa. I want to install gears, do a full exhaust system, calibrations and routine maitenance to my '95. I have contacted vette doctors, who at this point would rather not use, and also marc haibeck. I am leaning toward using him except for the fact that the cost of transporting is high. Does anyone know of someone closer to my area that could be trusted to this type of work? Thanks, in advance, for any help. Tommy B.
Gasman57 is offline   Reply With Quote
Old 04-25-2005   #2
Z Factor
Z Factor's Avatar
Default
Not sure where in PA you are, but according to another member this shop is owned by a LT5 certified GM Master Tech.
Brady's High Performance
Owner: Robert Brady
386 Millwood Road
Willow Street, PA 17584
717-283-0056
It can't hurt to give him a call.
Old 04-25-2005   #3
Gasman57
Gasman57's Avatar
Default
Owner: Robert Brady
386 Millwood Road
717-283-0056
Thank you very much Z Factor. I will give him a call. I will post back when I do. Thanks again.
Old 04-25-2005   #4
Gasman57
Gasman57's Avatar
Default
Z-Factor, I talked to Robert Brady of Brady Performance. He does work on ZR-1's and is a certified LT-5 mechanic. He will be able to do the work that I want done. I am scheduled to go in the first week in June. I told him that you were the one I got his number from and he said if I could get your name he would send you a coupon(he didn't elaborate). If you're intetested let me know. Thanks again for the tip. I will keep you posted on how I make out, etc. Tommy B.
Old 05-01-2005   #5
ZR-1Mom
Default
Also Tom Henry Chevy has always supported ZR-1 owners and this Registry.
http://www.tomhenrychevrolet.com/
He's in Bakerstown, PA
ZR-1 Mom
ZR-1Mom is offline   Reply With Quote
Old 05-01-2005   #6
Z Factor
Z Factor's Avatar
Default
Originally Posted by Gasman57
I am scheduled to go in the first week in June. Tommy B.
Your quite welcome Tommy, and I hope everything works out. He must be very busy to schedule an appointment a month away.
Don't forget to let us know how things turn out for you.
