Old 04-07-2008   #1
DaveK
Default C5 Rear Rotors
Would those fit on a C4? Got a chance to get all 4 from a C5 but not sure if the rears are worth anything to me. I'm working on updating the fronts to C5 calipers etc, but the rears would still be standard C4.
1991 #1516 Black/Black
davidmkelly.com
Author of fast-paced, sci-fi thrillers.
Old 04-07-2008   #2
djpatrick35
djpatrick35's Avatar
Default Re: C5 Rear Rotors
I'm no expert, but most people say to not change out the rears because you might screw up the parking brake.
djpatrick35 is offline   Reply With Quote
Old 04-07-2008   #3
No reason to change the rears out. Then again change the fronts to C5's =
Old 04-07-2008   #4
DaveK
I'm keeping the standard C4 calipers - just want to know if the C5 rear rotors will work with the standard C4 set up, otherwise I'd be buying two rotors that are no use to me.
Thanks
davidmkelly.com
