Old 04-05-2008   #1
Arctic91
Arctic91's Avatar
Default What is this?
So, after some encouragement from Uly (thanks!! I needed that), I decided to dive into a plenum pull/injector replacement myself tonight - instead of paying a few guys to help out.
The plenum is off, new wires are on, new injectors are in the rail and I'm ready to start buttoning it back up... then I see this horrendous-looking thing runing from one bank to the other under where the rear of the plenum should go: http://i256.photobucket.com/albums/h...1/IMG_1705.jpg. I have no idea how I didn't notice the condition of the hose during the removal - it's nearly cracked in half at three places!
I an 98% sure that this is the PCV hose and valves, but before I go off and order a new ones, I thought I'd make sure that I am asking for the right parts and see if anyone knows of a more economical solution than ordering from Kurt White? I'll call the local Autozone, Checkers, NAPA, etc. tomorrow, but I'm not optimistic that I'll find what I need local.
Thanks!!
Arctic91 is offline   Reply With Quote
Old 04-05-2008   #2
Jeffvette
Default Re: What is this?
LOL, damn somebody really did a shade tree fix on that.
it's the PCV hose. You can only get it from Kurt. http://www.whiteracingproducts.com/i...oducts_id=1012
Old 04-05-2008   #3
flyin ryan
flyin ryan's Avatar
didn't even use a black zip-tie to try & hide LOL. will be that much better when you get it together
Old 04-05-2008   #4
Arctic91
Arctic91's Avatar
Jeff,
That "somebody" would be Corvette Connection here in the Denver area... obviously not a "preferred" LT5 service location.
Thanks for verifying the sole source for the part. Damn expensive hose... and it was all going so smoothly until I saw that!!
Scott
Old 04-05-2008   #5
Jeffvette
The zip tie wasn't really a problem. But the two large cracks in the hose are. Probably not helping your emissions.
Old 04-05-2008   #6
Arctic91
Arctic91's Avatar
"didn't even use a black zip-tie to try & hide"
... very funny. I agree that black would have been MUCH BETTER. I forgot to rant about the zip tie and how the whole monstrocity basically fell apart when I touched it! It not only looks terrible, it doesn't even hold it together good!!
Old 04-05-2008   #7
Man, that's just plain ole ugly! It hurts just to look at it.
That piece of hose has to be in the top 3 most expensive rubber parts on a Z!
Old 04-05-2008   #8
Ouch, so how much are the PCV Valves then?
Old 04-05-2008   #9
Actually the aftermarket part is better thent he OEM at $250
PCV valves are not too bad at $14 but are those LT5 specific or will others form the local parts place work?
Old 04-05-2008   #10
32valvZ
32valvZ's Avatar
Hey when I did my plenum pull, I noticed the inj housing bolts were all pretty loose. Check them & the breather box bolts. My breather box bolts were finger tight!!
