Old 04-01-2008   #1
tccrab
tccrab's Avatar
Default Your ZF6 makes noises or won't shift, what to do?
Your ZF6 has problems, what are your options?
Chapter 1.
Replace or Rebuild?
Replace:
GM no longer supports the ZF6, so taking your car to local Chevy dealer isn’t all that great of an idea.
In fact, GM sold off its entire inventory of new and rebuilt ZF6’s several years ago, so your dealer would have to locate a rebuilt unit from a GM authorized rebuilder. He will of course add on a sizeable markup and a “stocking fee” so figure on paying double for the transmission. And don’t forget that the mechanic replacing your ZF6 has likely never seen a ZR1 before, so you will be paying top dollar for his “On The Job Training”. Luckily, replacing transmissions isn’t exactly rocket science, so you’ve got a 50% chance that he’ll get it right.
Most of the new/old stock ZF6’s that GM sold off would up in private hands.
I was able to track down at least 7 of the new/old stock ZF6’s during my search so they are out there, for now. 5 years from now, who knows?
The current market price for a new/old stock ZF6 runs between $1800 and $2500.
Be sure to add in at least $250 for shipping unless you are fortunate enough to locate a unit local to you. Shipping weight is approximately 220 pounds if the ZF6 is shipped in its original packing crate and pallet.
Rebuild:
ZF Industries has long since sold the ZF6 S640 product line to Rockland Standard Gear Inc. located in Sloatsburg NY.
http://www.rsgear.com
“Rockland Standard Gear is the only ZF-certified distributor/ remanufacturer for the S6-40 6-SPD transmissions found in the 1989-96 C4 Corvette. We remanufacture this transmission for ZF and GM. Call for information on getting your unit rebuilt.”
Their current price for an exchange ZF6 is $1895 plus shipping. They give a 1 year warranty on parts and labor. There is a $500 core charge if you don’t send back your old transmission. They will rebuild your transmission, but the price will depend on what is wrong and what they have to replace.
Parts for the ZF6 are VERY expensive.
Bill Boudreau, the “ZF Doc”; http://www.zfdoc.com does rebuilds and performance upgrades. He’s in Cave Creek AZ, a nice little “Artsy Fartsy” town outside of Phoenix. It's where Cave Creek Chili Beer with the jalapeno pepper in it comes from. Stay away from it at all costs(the stuff is Nasty!!).
His prices range from reasonable to not so reasonable, depending on the cost of parts, whatever upgrades you might want, and the time he spends on it.
Bill is a great guy and a wealth of information. I can't thank him enough for his guidance and patience in answering all my phone calls and emails and tolerating all my stupid questions.
Other Rebuilders:
There are other rebuilders that advertize that they rebuild ZF’s. I don’t know much about them. There’s a list over on the ZR1 Net Registry here:
http://www.zr1netregistry.com/ZR1_faq.htm#44
The ZF6 S6-40:
There are two versions of the ZF6; the “Black Tag” which was installed on 1990-’93½ model year ZR1’s and the “Blue Tag” version which was installed in the ‘1993½ -‘95’s.
Black tag units were assembled in Germany.
Blue tag units were assembled in the United States.
Black tag units are rated to 450ft/lbs torque, blue label units are rated to 400ft/lbs.
The contact ratio was increased in the blue tag units so as to reduce the “Growling” noise common to the black tag units.
The later model ZF6s do not have a Reverse Lockout Ring below the shift knob. They have a “Crash Through” to reverse that takes about 15lb of force to engage the reverse gear.
There are a few other subtle differences between the black tag and the blue tag:
  • The speed sensor plug is different on the blue tag.
  • The tailshaft does not have two holes drilled and tapped on the drivers’ side to mount the exhaust hanger on that side.
Rather than finding a new plug which I’m told is still available through GM, I just transplanted the speed sensor from my black tag into the blue tag.
Luckily the exhaust hanger has two bolts on the passenger side, so no problems there. I bent the drivers’ side away from the transmission a little so as to reduce the chance of vibrating against the transmission.
The ZF6 S-40 that is in the ZR1 is nearly identical to the one in the L98 & LT1 cars with the exception of the input shaft.
The input shaft on the ZR1 transmission is 190.5mm and the non ZR1 is 159.5mm.
The good news is that the input shaft from a ZR1 transmission can be installed into a non-ZR1 ZF6 relatively easily by most transmission shops.
There were significantly more ZF6s put into L98 & LT1 cars so it’s a lot easier and less expensive to find a non-ZR1 ZF6 and swap the input shaft from your old transmission into the new one.
Stay tuned for Chapter 2.
Removing the ZF6 at home, or...
"Honey, where's the Band Aids, and while you're in the medicine cabinet would you get me the BenGay?"
Old 04-02-2008   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: Your ZF6 makes noises or won't shift, what to do?
My trans froze @ 110 mph. A testament to our car's stout behavior,
I was able to pull over. Then I could only go into reverse.
Easy to back onto a trailer to transport home.
Had to drop the drive shaft to get it off the trailer.
I opted for a built trans from Bill Boudreau (with short shifter).
He is not cheap (you get what you pay for?) but I got a great trans and an open book of information.
Old 04-02-2008   #3
cuisinartvette
I have a customer who is an old timer, owns a local trans shop that rebuilds all kinds of ZF trannies and is familiar with the Vette ZF. Very reasonable, too.
I have no doubt BIll knows his stuff but 3500-4k for a rebuild, no way Id pay that. To each their own though.
On bringing him a new ZF and swapping parts to rebuild..He does keep 100% of the old/unused parts. I wonder...........
Old 04-02-2008   #4
Default Got my new ZF for $2600 shipped...
My ZF ('95/LT1) froze at 72 mph. Last spring Bill rounded me up a new one and opened up the oil galleries (better lubrication for the reverse gear that tends to starve, according to Bill B), and matched the syncro spring tension for smoother shifting. It was $2600 shipped. It was one very smooth transmission (blue lable), I can tell ya that.
That transmission worked like a charm...right up to the moment I met my dream car...the Z. Now I have a black lable ZF which seems to whine more (in low gear especially) than the blue lable one did.
Bill had the new ZF on hand, and I chose to go that route b/c he quoted a rebuild price that was actually higher than the new price, even with the modifications.
Bill expensive? Compared to what (I guess)? Bill specializes in our ZFs (among others) and gets to see them on a daily basis. This affords him a level of hands-on expertise that a general mechanic shop doesn't see. He's learned some very useful nuances w/ regard to dealing with the ZF's common failures, and ways to "harden" them when someone wants to pass some serious (500+) hp thru one.
I shopped my ZF around to some local speed shops/transmission specialists and compared pricing. Bill's $$ was comparable, except for the shipping was extra. I opted to let Bill B do mine - paying for some "tricks" and peace of mind having an expert doing the work brings.
Hopefully, I learned enough from Bill to keep me from breaking my "new" ZF on the Z. Was it worth it? I like to think so. I was certainly impressed with the performance and smoothness!! That's worth something.
P.
Old 04-02-2008   #5
Default Re: Got my new ZF for $2600 shipped...
I shopped my ZF around to some local speed shops/transmission specialists and compared pricing. Bill's $$ was comparable, except for the shipping was extra. I opted to let Bill B do mine - paying for some "tricks" and peace of mind having an expert doing the work brings.P.
Bills a good guy and his price is fair. You get what you pay for. I have all the records on my Z from the previous owners. In my 91s history it went through 4 transmissions that were replaced under warrenty. The previous owner went to Bill and had this transmission installed 6 years ago. Its still going strong. It was B&B and Cyro gear treated. I think Bill has picked up some knowledge along the way. Again you get what you pay for. GC
Old 04-02-2008   #6
Z Factor
Z Factor's Avatar
Thumbs up Re: Your ZF6 makes noises or won't shift, what to do?
Chapter 1.
Nice & informative write up worthy of reputation points.
Old 04-02-2008   #7
ZR1Vette
ZR1Vette's Avatar
For one who is still learning about the Z...this post is excellent and helpful..thanks for doing it
Michael
Old 04-02-2008   #8
cuisinartvette
Im not saying its not worth it, Im sure his rebuilds work as good as possible.
My post is based on getting a recent quote for $4000 .
Old 04-02-2008   #9
Billy has done a super job on the ZF6 that he did for me that is now in the 440. I'll be sending him another black tag to do as a back-up trans. I'm VERY hard on the transmission and clutch.. the power helps out a bit also. Gotta learn to drive that power a bit better.
Is it worth it ??..............you betcha !!
Oh and hat's off to Tom C. for a great post
Old 04-02-2008   #10
Good post TCs the man !
