Old 03-30-2008   #1
Bell Curve
Bell Curve's Avatar
Question Seatbelt dummy light
My 90 has the dummy light on for the seatbelt and the tension is always loose. Wasnt there a recall, and if so, is it still valid
Bell Curve is offline   Reply With Quote
Old 03-30-2008   #2
Default Re: Seatbelt dummy light
Yes there was, jeffvette had a way of looking at your VIN and putting it through the maintenance records process at GM to see if your car had that recall service performed. The problem now if wether GM will have your color seatbelt in stock or not. GC
Old 03-30-2008   #3
Jeffvette
Does your infl rest light come on when you turn the key to run or start the car?
Old 04-01-2008   #4
Bell Curve
Bell Curve's Avatar
Interior color is saddle and yes my infl rest light is on.
Old 04-01-2008   #5
Jeffvette
Infl rest light always on?
Old 04-01-2008   #6
Bell Curve
Bell Curve's Avatar
Yes
Old 04-01-2008   #7
Jeffvette
You need to fix the infl rest issue and your seatbelt light will go off. It's tied together.
Old 04-01-2008   #8
Bell Curve
Bell Curve's Avatar
ok thanks, but what about the tension and is the recall still in effect
Old 04-01-2008   #9
Jeffvette
Recall should be in effect. PM me your last 8 digits in the vin and I'll run it in the gm database and check and see if belts are still available.
