Old 04-16-2005   #1
markierm
Default CAM Shaft Sensor Replacement
I have removed the bolt that holds the sensor and the heat plate, however, I cannot get the sensor out. Is there a trick?
markierm is offline   Reply With Quote
Old 04-20-2005   #2
perrymitchell
Default camshaft sensor
There's no trick. You have to carefully pry it out. Use a small screwdriver and work your way around it. It is the 'O" ring that is holding it in.
perrymitchell is offline   Reply With Quote
Old 04-20-2005   #3
markierm
Default
Thanks
rmm
