I have the Old system with resonance except for the Resonator itself which is the new design. I bought a pair of mufflers off the CF forum that are newer. I called B&B and they said it would take care of the resonance. Now goldcylon is saying it is the Exit pipes....So WHICH IS IT? I am tired of getting jerked around.
#2 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-25-2008 at 09:34 AM. |
![]() Join Date: Jul 2007
if the Cones on the exit pipes also help with resonance, why not just buy the Cones then?
Summit sells just the cones http://store.summitracing.com/egnsea...DS=1&N=700+115
I already have the new resonator installed. Can I buy the exit pipes from them? How much are they?
if i might ask a? or 2 .how far out do your exhaust tipps stick?how mmuch clearence do you have fro that metal brace in the rear vanance?our exhaust systems i found are like a tuning fork .aftermarket hanger are too thin in the rear rubber mounts . also one should make the tipp go 2-3 in past the opening and at least 10-12mm oif clearence under the rear end that metsl brace . you might ck rons thread here on has anyone removced the mufflers.in it i shared what i did to stop my problem. a friend thats a noise control engineer actually helped me stop my problem. hope this helps . good luck .
#6 | |
Dynatech Vortex Insert Cones Don't get caught by the sound police. Rules--they're everywhere. When it comes to sound requirements, they can't be ignored. Don't take chances with sound control, or you may end up on the trailer. Vortex cone inserts from Dynatech easily install near the exit of the header collector or muffler outlet to reflect and dissipate sound energy, reducing the decibel level. Because the open area of the cones is greater than the area of the collector or exhaust pipe, there's no significant backpressure, so you reduce noise with little or no power loss. The cones are made from T-304 stainless steel and weigh less than 1/2 lb. each. Well Harold...... I think im on target as well. D
I will do both the cones and the mufflers. Just go toff the phone with B&B and they said the mufflers will help. I assume I need the 3 inch cones.
BTW, I live in Mississippi. No smog regulation nothing. When I get an inspection sticker, they check the lights, horn and wipers..pay $5 and roll. I don't have to worry about that stupid crap around here...I loved it when I had my Z06 (staright exhaust headers no cats=D>) |
#8 | |
#9 | |
![]() This is BEFORE the new style resonator was installed...but gives a better angle of the tips http://www.fototime.com/36BD3988FC84C1D/conv.wmv |
#10 |
The new B&B system is pretty quiet inside and out. (mufflers/resonator)
